20 Most Recent Desa International HRC201-4 Remote Control Questions & Answers
To turn on the remote you must press the POWER and LOCK buttons together.
Desa... | Answered on Nov 08, 2014
OPEN the r.control and clean the keypads for dirty, oxide, corrosion with contacts cleaner , tight the spring contacts batteries for better contact, use the plier and clean it.
and try again.
God bless you
Desa... | Answered on Nov 25, 2013
The remote works once the right room temperature is
sensed (66F) by the remote, This is a room temperature
triggered remote.However, if the thermostat at the
remote becomes defective, then there is no way that the remote will function. You have to do it manually.
Desa... | Answered on Nov 24, 2013
you must follow the instruction in according with your instruction manual. or download from www. retrevo.com or www.manualslib.com
God bless you
Desa... | Answered on Nov 13, 2013
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check out, which brand remote control has setup codes to your TV/Device brand. Setup code list & setup procedure to some popular brand remote controls are given. Check it, and determine which brand remote control should be bought, and buy that brand remote control, according to availability. If you wish to get more details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Desa... | Answered on Nov 07, 2013
The remote control was made by Skytech. You should get the information off of the remote and the valve and contact them for parts.
email
[email protected]
fax
888-672-8024
phone
888-672-8929
address
9230 Conservation Way
Fort Wayne, Indiana 46809
Desa... | Answered on Mar 04, 2010
The sensing device on the remote does not reflect the right room temperature to trigger or activate the remote igniter for the flame.
"The remote igniter is triggered by the room temperature". I'll get
back to you if the there's a way we can reset the trigger temperature.
Desa... | Answered on Oct 23, 2009
You cannot get lower than the 66 F. The manufacturer has set that as the default lostest setting.
Desa... | Answered on Jul 13, 2009
It cannot be repaired. Replacement parts are no available for this unit and it only had a 90 day warranty. You will just need to purchase a replacement. You can contact Master Parts at www.masterparts.net or by calling 800-446-1446. I hop this helps!
http://12.153.20.74/manuals/119426-01A.pdf
page 24 shows to unlock hold both buttons down
Desa... | Answered on Nov 04, 2007
Desa International HRC201-4 Remote Control Logo
24 questions posted
Top Desa International Televison & Video Experts
Marvin
Marvin
Are you a Desa International Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Desa International Televison & Video
Most Popular Question
replaced battery in our hrc200 handheld
  • Televison & Video
