CLICK HERE for your user manual.
You can save or print it for further reference.
Setting the clock is inside. (page 6) as follows...
Setting Clock Time and Calendar
Important - While setting the time or calendar, if you do not press the appropriate buttons
(as explained below) within approximately 8 seconds, the display will stop flashing. If this
happens you must follow the instructions again from step 1.
Setting the Clock Time
1. Press and hold the Time Set Button until the display begins flashing.
2. Press the FWD/Month or REV/Date Button to select correct time. Remember to
set the correct AM or PM. The PM Indicator is located on the upper left side of the time
digits (there is no AM indicator).
3. Press the Time Set Button again to return the display to normal mode. You can also
allow the display to flash for approximately 8 seconds to return to normal mode.
Note: While setting the time, if you press and hold the FWD/Month or REV/Date
Button the minutes will begin counting at a moderate pace, then get faster. This will
assist you in easily setting the time quickly and accurately.
Thanks!!
