20 Most Recent Seiko QHR016SLH Clock Radio Questions & Answers
Once the 'SET' button is pushed & held, & the numbers are flashing, turn it around to the face & use the ALM/TIME set buttons to adjust the numbers correctly. Then, continue on pushing the 'SET' button to cycle through the number positions & adjust everything else in the same way. Then, for language & temperature readout choices, push the 'OPTIONS' button & use the same ALM/TIME set buttons to cycle through the options, making your preferred choice. Be sure to push the 'WAVE' button to choose your proper region so it can receive the time signal. Worked for me. I use lithium primary AAA cells for the longest life.
Seiko QHR016SLH... | Answered on Nov 11, 2019
The time should be done on automatic by pressing WAVE.
To set manually:
Press the [SET] Button for more than 2 sec. The Year will pop up set to correct year then press SET again to set date/mth, keep holding till it get to right month n date (the month and date does not set separately). Press SET again and set TIME then press SET again for your choice of 12hr or 24hr.
Seiko QHR016SLH... | Answered on Dec 10, 2015
Remove the battery cover, press and hold set until it beeps. Use the up down keys on the front and you cycle through year, month/day, then time, then 12/24 hour mode. You advance to each function using the set key. Once through the cycle, the time will stop flashing and the clock will function normally.
Seiko QHR016SLH... | Answered on Mar 13, 2013
Seiko QHR016SLH Clock Radio Logo
43 questions posted
Top Seiko Audio Players & Recorders Experts
NOEL
NOEL
Andrew Taylor
Andrew Taylor
barn2897
Are you a Seiko Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Seiko Audio Players & Recorders
Most Popular Question
seiko clock model qhr016
  • Audio Players & Recorders
