20 Most Recent LG C1500 Cellular Phone Questions & Answers
Your cell phone may be locked to a particular cell phone provider and in this case it needs to be unlocked to use with a different cell phone service provider. To get the security code/restriction code to unlock the cell phone from the current cell phone provider so you can use the SIM card with a different phone provider, Please click on this link and follow my instructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then these WEB sites it provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw http://www.mobileunlocksolutions.com/ http://www.superunlockcodes.com http://unlockcellphonecode.com/
LG C1500... • Answered on Feb 11, 2013
PERSISTANCE IS KEY!
My Palm Centro sat in a small puddle for a few seconds, and the only thing that was wrong was that it was, like every other poster here: Stuck in Headset mode. For 3 days I read posts / forums all over the place, getting similar ideas about inserting/pulling out the speaker cord rapidly / soft or hard resetting / pulling out at a certain point etc etc.
The real problem was that inside the 2.5mm jack there is a little microswitch that enables / disables the headset function, and if it gets stuck open- nothing can override it. --- Again --- 3 full days of twisting, pulling out, screwing with the jack and wasn't able to get anything out of it- was about to say screw it.
THE ANSWER!!! -- I read somewhere that using a Qtip could increase my chances of snagging the switch down; I doubled my odds and sprayed the **** out of it with WD-40 (with the fore-idea that the switch got all gunked up and is stuck in the open position)
--To test it out, start playing a music file or anything that should originally go through the main speaker (or just call your Voicemail)
-- I got the tip wet with the wd-40, and since I have a 2.5mm jackport (not even the qtip stick fits in the hole) I started twisting the cotton off of the stick into an elongated portion of the wet cotton; long enough to fit in the port. I stuck it in (twisting in the same fashion as the twisted cotton) and just started twisting. About a minute worth then I yanked out and-- WaLaa! MUSIC
Only thing that worked in 3 days; I figure the individual cotton strands snagged on the thing and pulled it down, although I contribute it finally moving to the WD-40.
GOOD LUCK =)
LG C1500... • Answered on Jun 06, 2011
you can contact the service provider,they willhelp you to get the unlock code for your mobile
LG C1500... • Answered on Apr 19, 2011
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At the link below you will be directed to a tip i wrote on how to recover your PUK code.
Click HERE to navigate.
Kind regards
Lock123
LG C1500... • Answered on Feb 15, 2011
Security unlock lock codes can only be reset by calling your cellular provider and asking for Tech Support. After answering your security question, you'll be provided a security code. We do not provide security codes at FixYa as we are unable to verify the ownership of your phone.
LG C1500... • Answered on Jan 30, 2011
try unlocking sites
LG C1500... • Answered on Dec 07, 2010
i suggest for you to buy a nokia N81 cellphone..it has a talking caller id feature.
LG C1500... • Answered on Nov 02, 2010
you may visit some LG mobile sites.....
LG C1500... • Answered on Oct 30, 2010
Lg restriction codes for c1500
LG C1500... • Answered on Aug 29, 2010
I need the restriction code for LG C1500
2945#*#
LG C1500... • Answered on Jul 24, 2010
Your phone's headphone jack port is shorting. Try turning the phone off then dry it with a hair dryer for 5 minutes. Turn it back on and see if it helps, if it doesn't well you now have a permanent damage on your phone, its probably the headphone port controller, its busted...
LG C1500... • Answered on Jul 14, 2010
hi, it could be that the battery is bad....try see if you can change that...Also, it could be that you over loaded the phone beyond it capability so try delete some applications that you downloaded your self to free the memory space on your phone.
cheers
LG C1500... • Answered on May 29, 2010
This can not be done because both networks use different technology. One is GSM the other is CDMA. Frequency to transmit radio signals are entirely different.
br,
www.phonefreedomjamaica.net
LG C1500... • Answered on May 13, 2010
I would try a to reset by pulling the battery out then putting it back in.Leave it out for about 30 seconds.
LG C1500... • Answered on Apr 18, 2010
LG C1500 Cellular Phone Logo
49 questions posted
Top LG Cell Phones Experts
Sheldon Dedek
k24674
Daniel Dollive
Daniel Dollive
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
LG Cell Phones
  • LG Cell Phones
Most Popular Question
lg c1500 phone stuck headset mode no
  • Cell Phones
