20 Most Recent
Sony Ericsson Z710i Cellular Phone Questions & Answers
How can i unlock a
There are several methods for unlocking mobile phones, but codes are best one, because it is easy and safe also,
you can get the unlock code for your Sony ericsson mobile phone, through this site
http://www.theunlockspot.com/sony-ericsson/rs10wp8/It provides the step by step instructions and easy methods for unlocking mobile phones at a reliable cost itself..........
How do i install fido
To install a sim in to a Sony Ericsson Z710i:
- Remove the battery cover by sliding the battery release latch down.
- Slide the SIM cars into it's holder with the contacts facing down.
- Insert the battery with the label side up and the connectors facing each other.
- Slide the battery cover into place.
When I put on my phone a bright white light comes
if the lcd become white screen but the phone is working it means the flex cable of your phone is damage and need to replace, but if the phone not work with white screen your phone is in need to reprogam.go to cellphone repair shop.
When switched on the screen is white and keeps
Install a new battery for it. If it is not still working even if you change the battery then there must have been a problem with your phone operating software. Try removing the memory card and turn it on again. If it is still not working then bring your cellphone to the nearest cellphone repair center and consult your phone problem.
Freeze on start
Change your charger....charge the phone throughly for 6 hrs minimum and retry.............
Phone locked
Unless you've changed it, it is usually the last four digits of your phone number by default
Battery charger-leaking yellow liquid
No, it will not be safe to use it again, and yes, the yellow liquid is VERY DANGEROUS. Please do not use it again, you need a new charger.
i dont think the batery was affected, but if it was, you also need to throw it way and get a new battery.
