20 Most Recent
Nokia 7380 Cellular Phone Questions & Answers
How can i reset my nokia phone?
Go to the settings of your phone...go to settings, then find the restore factory settings..then enter the code if your code 12345 then press ok and that will start resetting your phone.
Hi.I would like to know
To replace the battery, then you need to turn to the back of the phone, then press the edge of the cover of the phone, then apply a little force in pushing up the back cover of the phone, then you will be able to gain access to the battery of the phone.
When I charge the battery runs down quick,I cannot
ist check whetherv there are any black spots on the battery connector .if u see any try cleaning them and keep the battery under sun for 3 to 4 hr .ur battery should work properly or else buy a new battery
Hang
remove them format the phone *#7370#
The phone wont turn on
usallly new phones must be charged for 6 hours . try doing it . try to locte any other buttons on the body of ur phone . if u cant find a (i) mark in end button then its not hte power button . nokias powe buttons are indicted with it . it amy be in the body of ur phone
Help Nokia 7380
there is issue with the speaker of ur fone...replace that///thnx...
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity.
