20 Most Recent Logitech Harmony 550 LCD Remote Control Questions & Answers
update the firmware
1. click "Downloads" at the top of the software, 2. select "Firmware" 3. Update the remote
if that doent fix it then it's a hardware issue.
Logitech Harmony... • Answered on Jan 17, 2012
I can help you with your Logitech Harmony 550 remote control.
The Users Guide is available here: Harmony 550 Manual Download
I hope that helps.
_____________________________________________
Logitech Harmony Firmware Update
Harmony Win Software Download
Harmony MAC Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Logitech Harmony... • Answered on Apr 30, 2010
Download Logitech Harmony 550 Remote Control Manual
Have you misplaced your Logitech Harmony 550 Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Logitech Harmony 550 Remote Control Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
Harmony Mac Software Download
on Apr 30, 2010 • Logitech Harmony 550 LCD Remote...
Tip
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Logitech Harmony... • Answered on Apr 20, 2010
1. Remove the batteries. 2. Press and hold the 2 button on the remote while connecting it to your computer. 3. The Harmony Remote LCD screen should display "Upgrade Success" 4. Unplug and test. If that doesn't work check your remote for stuck buttons then proceed to re-install the firmware on your Harmony Remote.
1.Remove the batteries from your remote 2. Massage each button with your thumb. Press down firmly to ensure that no buttons are stuck down NOTE: Stuck buttons may not be easily visible. It is important to massage every button regardless of its appearance. 3. Re-insert the batteries into your remote. 4. Launch the Logitech Harmony Remote software and login to your account:
  1. Click on the "Downloads" button
  2. Click on the "Firmware" button. Follow the onscreen instructions to upgrade the firmware on your Harmony
  3. Once completed, you will be prompted to update your remote. Please do so. If you were not prompted to update your remote, you will need to. Click on the "Update Remote" button and follow the onscreen steps
  4. Un-plug the remote from your computer and test
Logitech Harmony... • Answered on Apr 09, 2010
technically we call it debouncing it causes due to the faulty microprocessor in remote also it can happen due to faulty carbon contacts of remote below buttons.the solution to this is to replace remote but before that do one thing 70% THIS WORKS open ur remote then take a dry cloth & clean the surface below buttons if u r lucky then remote will be OK
Logitech Harmony... • Answered on Mar 14, 2010
Update the firmware.
1. In the software, click "Downloads"
2. Click on "Firmware."
That should fix it!
Logitech Harmony... • Answered on Mar 05, 2010
Try:
Learning the input commands for the audio device.
Increasing the inter-device delay and power-on delay for the audio device.
Hey!
I thought this link might help get your Harmony 550 working again:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=11941
Hope this helps!!!
-Kennedy
Logitech Harmony... • Answered on Feb 28, 2010
Changing the settings within an Activity:
1. Login to your Harmony Remote Account.
2. Click on the Settings button next the Watch TV Activity.
3. Choose Review the settings for this Activity.
4. When the software asks What input does the AV Receiver need to be on, please choose the Input that you herd sound coming from when doing the testing.
5. Continue through the setup until you are brought back to the Home Screen.
6. Click on the Update remote button and follow the on screen steps.
7. Once the update is completed, please test the Watch TV Activity.
Logitech Harmony... • Answered on Jan 25, 2010
This is a common issue. The following link shows how to set the default to (1) so that the harmony can control it:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=12151
Hope this helps! and have a nice day! =)
Logitech Harmony... • Answered on Jan 22, 2010
I just got off the telephone with Harmony support with the exact same problem. The rep. indicated that this is usually caused by one of the buttons being stuck. Sure enough, my #1 button was stuck. All is well now. Call 1-866-291-1505 if that does not help.
Logitech Harmony... • Answered on Sep 13, 2009
If it's out of warranty, take it apart and clean the parts.
Do a google search for cleaning tips.
My H628 had some dead buttons that didn't respond to cleaning, I used strong, thin double sided tape to attach a small piece of Al foil to carbon pad, then trimmed to fit. I did all the bad buttons and they all work now, at least till the tape falls off. If repair fails, I'll try foil and a dot of super glue and as a last resort I'll go for a $20 "Rubber pad remote repair kit". This is a silver containing paint that will restore the contacts.
Logitech Harmony... • Answered on Jul 22, 2009
Have you tried to contact logitech with your request?
Logitech Harmony... • Answered on Aug 08, 2008
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily... http://remotesearch.blogspot.com/ https://elektrotricks.blogspot.com/ https://electrohelponline.blogspot.com/ https://homenol.blogspot.com/
Logitech... • Answered on Nov 26, 2020
You can buy it from Amazon
Logitech... • Answered on Jul 07, 2020
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://homenol.blogspot.com/ http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device. Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts. {View the site in web view by Mobile or a desktop to see the search box. Mobile view has no search box.}...
Logitech... • Answered on Jul 05, 2019
Logitech Harmony 550 LCD Remote Control Logo
15 questions posted
Top Logitech Televison & Video Experts
Tom Chichester
Steve Pack
Steve Pack
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Televison & Video
Most Popular Question
remote actions things twice one button
  • Televison & Video
