20 Most Recent Nokia 6236i Cellular Phone Questions & Answers
manual
I,ve nokia 6236i .when i switchon my phone this show that UIM card rejected,how to solve this problem?
it is a network problem or you can enter uim card at a time.
3/26/2013 4:15:50 AM • Nokia 6236i... • Answered on Mar 26, 2013
3answers
Speakerphone on nokia 6085
I have the same problem. I called ATT and they didn't know. The manual doesn't explain it either. This is one of those problems that seem to have fallen between the cracks. ...
7/1/2011 4:00:07 PM • Nokia 6236i... • Answered on Jul 01, 2011
Nokia 6230i unlock code
As you have not specified which code you need i am hereby giving how to get all of the codes:
NETWORK UNLOCK CODE:
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA mobile , you can get the network unlock code(NUC) by just contacting the current network provider customer caredepartment.It is free of cost.
Therestrictioncodecan be got from your old service provider..This restriction code iskeptto prevent someone who stole themobile from using it withanotherprovider...
They will have a security check done with your date of birth etc..to verify whether you are the exact owner of the phone..
After that they will provide you the restriction code to unlock it and use it with another service provider..
It is all free of cost donot pay anyone for this seeing some advertisement over internet . That is all fake ads.
The above proceudre works and you can verify that by seeing the rating of an happy customer here..
http://www.fixya.com/support/t4035818-need_unlock_nokia5130c_2_use
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
6/1/2010 5:40:36 AM • Nokia 6236i... • Answered on Jun 01, 2010
4answers
Nokia 6085 headset
none of that **** work
9/25/2009 12:44:16 AM • Nokia 6236i... • Answered on Sep 25, 2009
Phone to PC bluetooth connection fails
after pairing if you answer cell phone calls on cell, the bluetooth will drop....you must delete pairing and then add it back and remember to answer only on house phone while they are paired.....
3/25/2009 12:23:53 PM • Nokia 6236i... • Answered on Mar 25, 2009
Nokia 6236 i
My Nokia gets that little headset icon when I turn on my bluetooth. Try going into the phone settings and make sure bluetooth is turned off.
11/20/2008 4:45:19 PM • Nokia 6236i... • Answered on Nov 20, 2008
Nokia 2760: How to turn on and the torch (flashlight)?
Nokia 2760 Flip User Guide
ctfassets.net https://assets.ctfassets.net > Nokia_2760_Flip_Onli... PDF TURN ON WI-FI. 1. Press the center key and select Settings >. Network & Connectivity > Wi-Fi. 2. Turn Wi-Fi to On. 3. Select Available networks and the ... 12 pages ..
4/12/2024 11:21:55 PM • Nokia Cell... • Answered on Apr 12, 2024
Nokia phone shows 'imei is corrupted'' what can be the problem? pl help.
That could be the result of someone trying to jail break the phone. The IMEI numer is a specific identification number for that specific phone and if changed will render the phone useless.
4/7/2024 5:16:58 PM • Nokia Cell... • Answered on Apr 07, 2024
Nokia phone says 'IMEI is corrupted' after coming from technician who tried to unlock it. The phone is from Australia. I'm in Sri Lanka. Please help.
Question edited for clarity. So the phone was likely stolen in Australia and shipped to Sri Lanka for sale. For the technician to unlock it by playing with the IMEI, it must have been PUK Locked AKA a SIM Lock. To remove a normal customer set PIN Lock, you just do a hard reset which scrubs the phone clean and reloads the operating system with no lock. A PUK Lock can only be removed by the carrier that provided the phone. The technician tried the impossible task of removing an RSA 128 bit encryption lock by playing with the firmware and corrupted it. You have three choices 1. Give it back to the technician and tell him to fix his mistake 2. Send it to Nokia to have the firmware and IMEI reinstalled 3. Throw it away. Have a read of this Fixya Tip I wrote. https://www.fixya.com/support/r26230986-phone_asks_puk_code_ask_another_way ..
4/7/2024 4:53:33 PM • Nokia Cell... • Answered on Apr 07, 2024
Nokia phone got from australia couldnt be unlocked .im from srilanka, its like blacklisted pl help. nokia g21 ta1415
If it is blacklisted, contact Nokia and prove ownership. They may then be able to help.
4/7/2024 8:18:37 AM • Nokia Cell... • Answered on Apr 07, 2024
How to fix a nokia c5 writing sim card not valid
Contact your service provider, they can clear it for you.
3/20/2024 9:53:47 PM • Nokia Cell... • Answered on Mar 20, 2024
2answers
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone. Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
3/20/2024 10:17:39 AM • Nokia Cell... • Answered on Mar 20, 2024
Nokia 1203 imei 353**********58 Security code
Never post IMEI numbers in an open forum like this. It is the unique number that identifies your phone from any other phone in the world. Those with malintent can clone a phone with your IMEI and you magically pay for their calls. This website gets 11 million views a year and the site has an excellent search feature!
How to reset nokia 1203 security code
Ask Me Fast https://www.askmefast.com > How_to_reset_nokia_1203... You can cancel the security code of your Nokia 1203 device by pressing and holding down this buttons: * + 3 + call + Power on. Before the device will reset, ... ..
3/19/2024 4:14:22 PM • Nokia Cell... • Answered on Mar 19, 2024
Nokia 6111 security code
How to do a hard reset on NOKIA 6111?
HardReset.info https://www.hardreset.info > devices > nokia-6111 Swich off the handset. Hard Reset NOKIA 6111; Then press and hold Call button + * button + 3 button + Power button, until you see Nokia logo.
NOKIA 6111 secret codes and hidden features
HardReset.info https://www.hardreset.info > devices > nokia > codes *#7328748263373738# resets security code. Default security code is 12345. *#1471# Last call (Only Vodafone). *#21# Allows you to check the number that "All ...
3/16/2024 1:06:04 AM • Nokia Cell... • Answered on Mar 16, 2024
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity. ..
3/12/2024 2:49:32 AM • Nokia Cell... • Answered on Mar 12, 2024
I have a Nokia mobile phone locked into Tesco, they have supplied me with an unlocking code which appears to be too long. It does not unlock the phone what can I do?
You normally can't do that. The phone is locked to Tesco in the UK, you can only use their service provider in the UK. The long code is a PUK Lock / SIM Lock code and will lock you out when you put in another SIM Card. If you want to use it in Cyprus. you use a roaming package with Tesco. Or you buy a Cyprus phone. https://www.fixya.com/support/r26056685-phone_asking_puk_code ..
3/12/2024 2:41:50 AM • Nokia Cell... • Answered on Mar 12, 2024
Hello I lost my security code mobile phone nokia 5200 plz help. IMEI NO: 35**********3320551048
This phone is an antique from 2006!
How to do a hard reset on NOKIA 5200?
HardReset.info https://www.hardreset.info > devices > nokia-5200 Next confirm Factory reset operation by clicking Call key. Permanently delete data from NOKIA 5200; Done, operation is done you can work properly on device.
Hard Reset for Nokia 5200 - HardReset24.com
hardreset24.com https://hardreset24.com > instruction > hard-reset-for-no... In order to hard reset a Nokia 5200, you should perform the following steps. Remember! Hard reset will delete all the data on your device; pictures, contacts, ...
NOKIA 5200 secret codes and hidden features
HardReset.info https://www.hardreset.info > devices > nokia > codes The whole list of secret codes for your device. Check out how to get access to hidden mode, advanced features and secret options. ..
3/12/2024 2:36:02 AM • Nokia Cell... • Answered on Mar 12, 2024
Nokia 6236i Cellular Phone Logo
12 questions posted
Popular Products
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
View Most Popular
Nokia Cell Phones
  • Nokia Cell Phones
Most Popular Question
nokia 6230i unlock code
  • Cell Phones
