20 Most Recent
Sprint PCS Phone SCP-2400 by Sanyo(r) (Misty Rose) Cellular Phone Questions & Answers
Blocking numbers on cell phone
Unfortunately, Sprint does not have the ability to block single numbers from calling you. We can either block all incoming calls, all outgoing calls, or both, but not particular numbers.
When dialing voice i get busy signal on scp 2400 sanyo
First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.
I have a Sprint Taho, is a Sanyo by Kyosers cell
Connecting Your Phone to Your Computer:
1.Press Menu(OK) button >Tools>Memory Storage>Connect to PC (You will see a confirmation
message.)
2.Press OK (left softkey) to continue.
3.Connect your phone to your computer using a compatible USB cable. (Wait for the connection to be completed. When connected, the host computer will automatically detect your phone.)
No driver installation is required for Windows 2000/ME/XP/Vista/7 users
How do i change the language back to english on my
Hi carebear2761, to change it back to English:
1. Select the round Menu/OK button Then > Settings > Language > English . Should be done.
Since it's in Spanish currently, you may have to go to Settings > Language > Others > English. Let me know what happens. If you need further help don't hesitate to ask. Thanks for using FixYa.
Jeff.
I dropped my phone in the pool and the screen has
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Can I unlock my sprint phone to work for verizon
it is very unlikely but it depends on the type of phone. I have a Sprint phone and the same model phone is mechanically different from verizon's phone although the outside looks the same. I would suggest aasking Verizon but I assume that they would tell you no, even IF it were possible just to get you to buy one of their phones. Try going to www.craigslist.org and search for "unlock" under the services tab Hope this helps..good luck!
Can I unlock my sprint katana lx phone to work?
A lot of sites do unlock but there is this site I used couple of times and it pays best since I've been unlocking phones.
You get full money back guarantee.
Visit http://www.mobileunlocked.com/index.php
and just follow the site prompt.
Good luck and remember to rate this solution.
