20 Most Recent
Cavalry Storage Cavalry CAUO37500 500GB OneTouch Ext USB 500 GB USB 2.0 Hard Drive Questions & Answers
The drive will not spin
you have a dirty hard drive the clicking sound is the reader arm skipping across the hard drive platters give your hard drive a firm tap to side which will free up the reader arm once you freeze it it will only last a short amount of time
Wd Hdd inaccessable
try to disable all firewall setings or antivirus...after try accesing frome ur command prompe if u can that the windows is blocking the hdd...uninstall any new software or driver and try again...no effect ok dowload ophcrack live cd frome google and access the hdd by force repare or scan it in surface scan that will fix ur clusters problems that might be in the back off this prob an du know wer e2 go frome there
CAUM37500 CAVALRY HARD DRIVE NOT GETTING DETECTED
head crashed is the most likely reason.
drive has lost its directory and boot segment address.
you have lost your drive functionality.
the drive would need to be much larger than average to bother fixing, but if you need the data, then you can send it in for repair. expect 500 to 2500 for data recovery/repair.
sorry for the news.
mark
Cavalry hard drive gets error message
click start control panel administrative tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if it's a program file you might uninstall the program restart your computer then reinstall some of these files/software
hope this helps
Constant beeping from Cavalry external HD
Can't say exactly what it means technically speaking, but my experience with such a problem is that the drive is 'dead'. Of course trying it on another computer would be constructive.
My black calvary external hard drive won't turn on.
Would be great if the next time you also place the model number, because Cavalry makes dozens of different drives.
When the bleu light does not go on, you have to assume the drive is not getting power.
If the drive has only one cable, (small drives like 2,5 inch most of the time only have one cable) it could be the USB cable is defect and can't give through the 5 Volt coming from the computer USB connector. It also could be the 5 Volt supposed to be in the computer has gone.
If you have to connect an external power supply, with a small cable to the drive, I would check the power supply. A 5 Volt 2 A supply, with the round plug can't be that expensive.
If both don't work, it also could be inside the housing of the drive is something defect.
If you need to have the data on the drive, you always could but an universal USB connection for hard drives. I have one for IDE and E-SATA, in the box came a set power cables and a power supply, but that one was almost 50 dollar. There are cheaper ones on the net.
Be aware drives don't live forever and make sure you always have at least two backups. (that is more than one origin; and one back up)
Error message says I don't
It sounds like your network administrator has locked your ability to write to certain folders. If this is a home hard drive, the only way to fix this would be to completely reinstall windows. If it's a work computer, you need to talk to your IT Department.
-Alex
CAUO37500 Lite's on but nobody
im not sure how bad your hard drive is but if it works on another computer
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps also
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
