20 Most Recent Lexmark Z1420 Printer Questions & Answers
For all devices you need to install the software first and then try to connect the device. Try the software that came with the printer, or goto Brother and download their printer sofware.
Lexmark Z1420... • Answered on Mar 29, 2015
You might not be able to find the "paper holder" for your printer that you can purchase. Please contact Lexmark Technical Support Center for additional assistance.
Lexmark Z1420... • Answered on Jan 23, 2012
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark Z1400 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Follow the steps below to fix the problem:
1. Align the print cartridges (open the Lexmark Solution Center on your computer > from the Maintenance tab, click Align to fix blurry edges > click Print) 2. Clean the print cartridge nozzles (open the Lexmark Solution Center on your computer > from the Maintenance tab, click Clean to fix horizontal streaks.) 3. Remove and reinsert the print cartridges. 4. Wipe the print nozzles and contacts using a slightly moistened soft cloth to clean it from dirt or clogs.
Lexmark Z1420... • Answered on Oct 24, 2011
Please visit the Lexmark website to download and install the Lexmark Z1420 printer driver on your computer. Select your operating system > click on FILTER > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen.
I hope this helps. Thanks.
You can print directly to the printer using the USB cable. Simply connect the cable into the printer and into your computer. Wait until your computer completely recognizes your printer before you print (a notification should pop up on your screen).
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolve your concern, your rating will be greatly appreciated. Thanks.
Lexmark Z1420... • Answered on Oct 21, 2011
If you're not connected to your wireless network, you can print to the printer via the USB cable. Simply insert one end of the cable into the usb port on the back of the printer and the other end to your computer. Wait until your computer completely recognizes your printer before you print (a notification should pop up on your screen).
It could be due to the refilled cartridge in your printer. Refilled cartridges tend to degrade print quality and in performance. Try to replace your cartridges with genuine Lexmark cartridges.
Lexmark Z1420... • Answered on Sep 26, 2011
Remove and reconnect printer.
Check for leakage.
Ink Scanner damaged.
Lexmark Z1420... • Answered on Sep 14, 2011
Please try to reset your printer's wireless network settings. Refer to this article on How to Reset the Z1400 and Z1500 Series Network Settings. Once you reset the printer's network settings, the Wi-Fi light will momentarily turn off then on with orange light.
You can then run the Lexmark Wireless Setup Utility application on your computer to reconfigure the printer to reconnect to your wireless network.
Lexmark Z1420... • Answered on Sep 02, 2011
I Have The Same Problem Any Help ?
Lexmark Z1420... • Answered on Aug 26, 2011
http://support.lexmark.com/index?page=productSelection&linkSelected=node0&locale=EN&userlocale=EN_US click the above link to download the driver of your printer select the right model & windows that you are using now,
Lexmark Z1420... • Answered on Aug 07, 2011
Lexmark Z1420 Printer Logo
114 questions posted
Top Lexmark Office Equipment & Supplies Experts
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Z Lexmark
  • Z Lexmark
Most Popular Question
lexmark z1420 not wireless used
  • Office Equipment & Supplies
