20 Most Recent Chevrolet 1995 Chevrolet S10/s15/sonoma Radio Questions & Answers
Check the idle control module for proper operation. A diagnostic est will throw a code if it isn't.
Chevrolet 1995... | Answered on Sep 10, 2016
Sounds like crank or cam sensor
Chevrolet 1995... | Answered on Feb 08, 2015
there is 8 bolts around the bell housing on the transmission the two that you are missing are at the very top of the transmission bell housing to get to them you can try getting them from the top right there behind the firewall I mean by the or once you have taken the crossmember out that holds it transmission behind right there on the tail shaftmake sure you put a jack under the transmission on the belly pan and then slowly let the transmission down about 3 inches 4 inches then you'll be able to see the two bolts at the top just take one or two long extensions and you're 15 millimeter socket and go to town on it's all I can say
Chevrolet 1995... | Answered on Jan 22, 2015
You're the guy with the transmission that doesn't wanna go in. I was under the impression that you had the rear of the engine supported with a jack or something else to keep it from hanging with the transmission removed. Most engines need this or they will droop in the rear. If your isn't supported and needs to be lowered in the rear, putting a jack under the oil pan won't help. There are motor mounts of the right and left side of the engine holding it in place. These have rubber blocks that dampen vibration while the engine runs to make a smoother ride and less cabin noise. You may need to look and make sure that the distributor and or other parts at the top rear of the engine are not against the firewall. This can happen and will hold the engine's rear up. If the distributor cap is against the firewall, you can gain an inch or two of drop if you remove the cap and rotor. You will have to raise the engine to clear the cap while you do it. To raise the engine, place a wood block under the oil pan and jack it up from there.
Chevrolet 1995... | Answered on Jan 20, 2015
Re-installing a transmission can be troublesome, especially if you don't have the luxury of a transmission jack to aid you. The key to quick and easy assembly is luck and alignment. The transmission must be perfectly aligned or it won't slide into place. If you are hitting on things trying to get the alignment right, you may need to lower the rear of the engine a bit. Having it level or where you think it should be normally is too high to get the transmission to clear the tunnel area. One you get the transmission mated, then raise the rear of the engine back up.
There are usually 6 or 7 (there may be one at the very top of the bell housing). You may have to separate the trans from the engine with a prybar...they can get stuck. Remember to support the transmission when pulling back on it, because once you drop off the alignment pins, all the weight will shift to the splined shaft going through the clutch disc. You don't want all the weight hanging on that shaft. It can cause binding and bushing/bearing damage.
Chevrolet 1995... | Answered on Jan 18, 2015
In a word....Yes! This is a big job because typically the fuel pump in the tank cannot be accessed without removing the fuel tank. Get professional help.
Chevrolet 1995... | Answered on Oct 14, 2014
check the emergency brake pedal and see if it is up all the way.you may have corroded brake cables that are not letting the emergency brake pedal far enough up to turn the light off
Chevrolet 1995... | Answered on Sep 18, 2014
Check light bulbs .check fuse under dash
Chevrolet 1995... | Answered on Nov 19, 2012
easy fix
How to Unfreeze an MP3 Player ' Techwalla
www.techwalla.com > Around The Home > Entertainment
An MP3 player may freeze up due to a bad file that has been uploaded onto the player, or because of an internal software error caused by no fault of your own.
Audio Players &... | Answered 3 days ago
i think you cant convert audio to text using some softare because their quality was not good .Even i suggest you to try www.transcriptionsservice.com to transcribe your audio to text.Because am using their service and their result was good.
If you are using windows os, you may try Video Downloadhelper plugin on Firefox explorer. very easy to use
https://addons.mozilla.org/en-US/firefox/addon/video-downloadhelper/
Or, you own a Mac computer, you may try youtube converter to automatically download videos off youtube and then convert to mp3 audio.
http://www.ilikemall.com/youtube-downloader-for-mac.html
Audio Players &... | Answered on Jul 08, 2020
I use Allavsoft to download Spotify music to MP3
http://www.allavsoft.com/how-to/spotify-to-mp3.html
It also helps to download from Deezer, Soundcloud, YouTube, etc. Spotify to MP3 Download Spotify Playlist Music to MP3 WAV AAC
Chevrolet 1995 Chevrolet S10/s15/sonoma Radio Logo
24 questions posted
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Glenn Smart
Glenn Smart
Vernon Taylor
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Chevrolet Audio Players & Recorders
Most Popular Question
best way lower rear engine
  • Audio Players & Recorders
