20 Most Recent Chevrolet 1995 Chevrolet Blazer S10/jimmy S15 Radio Questions & Answers
check sparkplugs,air filter fuel filter replace them all and clean the mass airflow sensor in the intake tube after the air filter.you need to establish a baseline first before proceeding.
Chevrolet 1995... | Answered on Oct 12, 2016
it sounds like your heater moter has a short try unpluging it
Chevrolet 1995... | Answered on May 17, 2016
my wiring shows no relay,wiring goes direct from stereo to speakers, have you tried to adjust the fade control on the stereo?
Chevrolet 1995... | Answered on Aug 10, 2015
If possible try switching the wires on the neutral safety switch or pull off the plug and turn it over, so the contacts are on the opposite terminals.. If that doesn't work, it's possible you got a bad switch right out of the box. It DOES happen.
Chevrolet 1995... | Answered on Jan 12, 2015
Neutral, however you can move the tang to fit the slot when installing. Just make sure the new one matches your old one when you remove it, and make sure your new one matches, you will be fine.
Chevrolet 1995... | Answered on Jan 11, 2015
Could be exhaust damaged and letting fumes into cabin!
Chevrolet 1995... | Answered on Oct 04, 2014
You may have a short to ground meaning your wires are pinched together or you have the lead to one or more of yor devices touching metal. Thats two options the other one is one of your devices may be bad and hopefully this is the case. To test that theroy you will need to have several spare fuses. Start by unplugging one device at a time them inserting a new fuse and keep doing this process until the fuse doesnt blow then you wil have your culpret. If that doesnt work you will need an electrical specialist to track down which part of your wiring is shorting your fuse out. I would try your cigarette lighter and horn first.
Chevrolet 1995... | Answered on Sep 19, 2014
Have you checked the fuse? Do you have power to the switch? Do you have power from switch to regulater? If so than you need to replace window regulater. Of you can hear the window regulater working but the windows isn't moving it could be as simple as some plastic clips. If so remember to clean and lube the tracks.
Chevrolet 1995... | Answered on Aug 08, 2014
There are multiple temp sensors on that ,. One is in the MAP sensor and the other is the radiator. What is extremely cold?
Chevrolet 1995... | Answered on Dec 04, 2013
the grab handel has 2 bolts that need removed i belive they are 5/16 as for the rest of the panel slip a flat bar behind between the door and panel and pry gentle as not 2 break the door panel it is held on by push pins that you can buy at your auto parts store its sounds harded than it is
Chevrolet 1995... | Answered on May 24, 2013
Chevrolet 1995 Chevrolet Blazer S10/jimmy S15 Radio Logo
19 questions posted
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Vernon Taylor
gludwick2
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Chevrolet Audio Players & Recorders
Most Popular Question
front passenger window not work knnow
  • Audio Players & Recorders
