20 Most Recent
Milwaukee tools Milwaukee Tool 6527-6 Questions & Answers
Milwauke 6527 Sawzall motor runs but something is wrong with the internal workings
This may be of no help but I believe that the reciprocating shaft is oblong on one side and more of a round hole on the other. It has to go in with the oblong down engaging one of the two wobble plates. It would be item 51. Also if you removed the wobble plates (37, 38) the shorter of the two (38) goes towards the rear. Also make sure the spacer (item 64) is in there and not messed up. Also check needle bearing item 4 and make sure it fits well on the gear shaft.
Milwaukee 6527 diagram
Why my Makita disc cutter has spark wont start
If the fuel in it is 2 or more months old dump it out and put in fresh fuel and try statring. Also try try a squirt of starting fluid into the carb. If it fires on it you may need to do this a few times to pull the old fuel in the lines through till the fresh fuel can get to the carb.
4/10/2024 4:13:02 PM •
Saws
Answered
on Apr 10, 2024
Clean grease off terracotta tiles
There are a couple of things you could try. I recently came across a specific grout/tile cleaner that works well. You can buy it online. It is a type of cream that you spread over the grease and leave for a while. After it has set, you can use a toothbrush (for best results) to scrub off the soap and grease. Otherwise, you can try magic eraser. Those can be used on tiles and get off a lot. Tiles make up such a great aspect of the house, I hope you can clean them up.
Elisa Jed '
http://www.herrmanntiles.net.au
12/2/2023 11:11:55 AM •
Saws
Answered
on Dec 02, 2023
