20 Most Recent
Milwaukee tools Milwaukee 48-59-2401 12-Volt Lithium-Ion Battery Charger factory reconditioned Questions & Answers
Is there a fuse in that charger?
yes look first at the print circuits where are heavy components like the coils are re-solder them when the charger was fall down the first thing is a print fracture in the solderings , but first measure if a mos n fet is shorted ..... there can also be a shorted diode for responsible or a bulged capacitor. or some loose component by heat up. most its primary (hot) defect, not secundary
Difficult to get active - spareparts for it
Milwaukee tools...
Answered
on Jun 08, 2016
What is a miter saw?
Miter saw, similar to circular saw, use a flat circular blade to cut wood, MDF and other materials including plastic and aluminum (with proper blades). But it also has special features to do accurate crosscuts. The tool can also cut bevel and make "miters" - cuts at any angle other than 90° (
miter vs circular saw)
Saws
Answered
on Jan 14, 2021
Are chop saews a d miter saws the same thing?
It is a matter of terminology. A chop saw is geared more towards cutting bulk things and is heavy duty. A miter saw is precision wood working equipment for cutting angles. It would help to know what make and model you are wondering about
Saws
Answered
on Jan 01, 2021
How to fit blade in performer 350w jigsaw
There is a blade release that you have to push up while inserting blade. If this isn't the problem, there are many types of blades for different jigsaws. You need the one for your brand. Take an old blade with you when you purchase. Good luck
Saws
Answered
on Dec 02, 2020
I need source 2 carbon brushes for a Jura F50 grinder motor?
If you can't obtain brushes as a spare part for your grinder, there are many companies around the world that will be pleased to make a set for you, usually for little more than manufacturer's own. They will probably need one of the old brushes as a pattern.
We have at least half a dozen such companies in the UK and I expect there are some where you are.
Saws
Answered
on Nov 30, 2020
