20 Most Recent Pyramid Pr-8200 Echo Stereo Dj Mixing Board With Echo Questions & Answers
USE THE TAPE IN AND OUT DONT FORGET TO TURN ON THE TAPE MON IN FRONT
Pyramid Audio... | Answered on Jun 22, 2017
Hi, yes sure you can. Just be sure when disassembling to make notes where necessary to keep track of where parts go-and when you get to the lamps ( either under or in back of the meters-use a volt/ohm meter to measure to voltage so you know the size to replace them with ie.. a 6 volt or 12volt. be careful when powering on a disassembled unit ( no parts touching each other, touching a metal part of cabinet) and if you want you can wrap some electricians tape around loose or exposed parts for safety. Good luck, I hope this was of some help and thanks for choosing FixYa. Prodzilla
Pyramid Audio... | Answered on Apr 20, 2011
The pb180 has High Input receptacles on the back end. They are marked High Input and identified as Channels 1&2 left/right, and channels 3&4 left/right. You will need to identify all speaker wires coming from your head unit ( left front +&--) , and so on. You will be sending the speaker wires from the head unit to the pb180's High Inputs. In other words, the front left speaker wires(+&-) from the head unit will go to the High Input Channels 1&2 side, left input of the pb180, and so on, so the speaker wires coming out of the head unit will need to be cut. And LABEL all sets of speaker wires before you cut them! Then on the OUTPUT end of the pb180, you will be sending the wires back to the the respective speaker wires which are going to the speakers. So it's out from head unit to pb180 and out from pb180 to speakers.
Hopefully you have the plugs that Pyramid uses for the speaker wire inputs to the amp. If not you have to get creative, and make up terminals to fit into the input receptacles. Maybe a wire terminal from Radio shack will fit those pins..
Also, if you go on line: Google search "Pyramid auto amps" and click on "SEARCH" (upper right hand) of their Web Page. Plug in your model number like this, pb180, and you'll be able to download the manual for this amp. The manual has a full description of the wiring options.
Hope this was helpful and Good Luck!
Pyramid Audio... | Answered on Jul 27, 2009
is the positive cable hooked to the battery or the fuse box and it sounds like a grounding problem
Pyramid Audio... | Answered on Jun 30, 2009
Change the Capacitor C110 (47FU 25v) I found this solution on another post somewhere and it has worked on mine too.
Audio Players &... | Answered 1 hour ago
it's output power amplifier problem pls check and change ur faulty ic
Audio Players &... | Answered Yesterday
Repairs a corrupt EDB File from Exchange Server such as Exchange Server Recovery software,by this software one can very easily repair corrupt or lost EDB files as well as convert them into useable Outlook PST files.
Download:- EDB to PST Converter
here
https://www.allpartsinc.com/circuit-board-avr-automatic-voltage-0065649.html
NOTE
This 0065649 AVR Automatic Voltage Regulator has replaced the older style AVR's used by Coleman and Pramac.
The 0065649 AVR and the S0062490 Wire Harness should be ordered together if you are replacing any of the old style AVR's including the following part numbers:
0062479 AVR Automatic Voltage Regulator
0052627 AVR Automatic Voltage Regulator
0052795 AVR Automatic Voltage Regulator
or here
https://www.arkansas-ope.com/CANADA_COLEMAN_GEN_PARTS.html
After connecting one, turn on the other. Then while both are powered on? Press and hold the button on both earbuds until they connect to one another.
Audio Players &... | Answered 2 days ago
Check the connections you have made properly or not, after that if there is no sound coming then maybe your subwoofer has defected and also check the subwoofer its wire are connected to the coil or not.
Audio Players &... | Answered 3 days ago
To turn off alarm1 press button named "up" and for alarm 2 press button "down" Note: No need to press mode or set anything you just need to press the above specified buttons directly when it is normally displaying the time
Audio Players &... | Answered on May 29, 2020
If your sound cuts off, the problem is usually in the stereo wiring. ... When a power or ground connection is loose can cause a connection to break or short.
Audio Players &... | Answered on May 28, 2020
Pyramid Pr-8200 Echo Stereo Dj Mixing Board With Echo Logo
1 questions posted
Top Pyramid Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Pyramid Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Pyramid Audio Players & Recorders
Most Popular Question
replace bulb
  • Audio Players & Recorders
