20 Most Recent
DFI INFINITY 975X/G Motherboard Questions & Answers
How to configure Sata disks?
Try them individually. Are you sure you have all the power connected, it sounds very unlikely that it wont recognise them. Also try resetting the bios to default
Dfi games
http://www.gamesfree.me/games/tags/dfi/
Hackers unite
That will be a very big blob of goo! Or a very large and wobbly hacker.
DFI Infinity NF4 SLI won't start
Hi steve, PC repair is trial & error. I suggest you replace the power supply or test the power supply in another PC that also uses 4 SATA drives & two PCI-E slots for starters. Two boards with the same problem is odd. You must have the CPU & fan connected, memory installed, ATA 24_pin main power plugg connected (Page 17 in manual). 4-pin_12v power connected which is located (Just to the left of DDR1 memory slot). Looking at you're board the power supply should be no less than 500w.
CPU must have thermal grease between CPU & heat sink.
Even though you have fans running & LED's on & flashing, the power supply seems to be the first item to check. Make sure the bottom of the motherboard is not touching the PC case.
Try the above & post you're finding here.
Good Luck!
Mike
