20 Most Recent Lite On LiteOn LH-20A1P - Disk drive - DVD±RW (±R DL) / DVD-RAM - 20x/20x/12x - IDE - in Burner Questions & Answers
try downloading VLC player
It is free, and it plays almost every video format
Lite On LiteOn... • Answered on Feb 24, 2020
try to clean...with cd cleaner
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area If this does not fix the problem you might try you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or if this does not fix the problem it might be a registry problem Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps you
Lite On LiteOn... • Answered on Oct 07, 2011
if your computer came with a motherboard disk the drivers could be on it click start control panel administrative tools computer management device manager scroll down cd dvd rom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver if you dont have motherboard disk you will need to download the drivers http://download.cnet.com/dvdram-en-20071009085435-zip/3000-2110_4-172943.html http://download.cnet.com/dvdram-en-20070907111350-zip/3000-2110_4-170034.html http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html Adaptec's UDF Reader enables MultiRead CD-ROM drives to read UDF-formatted CD-R and CD-RW discs (such as those written with DirectCD) under Windows 95/98/98SE/NT 4.0/2000.
hope this helps you
Lite On LiteOn... • Answered on Oct 03, 2011
Thats a very unusual problem. I have had this drive in the past and apart from being noisy as all lite-on's seem to be it has given great service. the only suggestion i can make is that you update the firmware by going onto Lite on's site and download the latest revision of firmware. if still the same then can only assume the drive or your burning software is corrupt.
Lite On LiteOn... • Answered on Aug 07, 2011
make sure that the cd/dvd rom is getting enough power test all leads that are attached to the dvd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd rw then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
Lite On LiteOn... • Answered on Jun 10, 2011
Please describe the problem that you are experiencing.
Lite On LiteOn... • Answered on Feb 26, 2011
Possibly a broken belt.If you use a paper clip to open the tray (emergency procedure )
Will the disc play etc
Lite On LiteOn... • Answered on Feb 22, 2011
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or if this does not fix the problem it might be a registry problem Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete dont forget to vote hope this helps
Lite On LiteOn... • Answered on Feb 05, 2011
make sure that the dvd-drive is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this dvd drive then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Lite On LiteOn... • Answered on Jan 16, 2011
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall hope this helps if this does not fix the problem it might be a registry problem Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
Lite On LiteOn... • Answered on Jan 01, 2011
I was having a problem getting my dvd (Lite-On LH-20A1P) to read my cds. I found a very simple solution that worked for me. I hope the following procedure works for others.
I have windows xp (I believe this solution may work for other window versions)
Go to "My Computer" on desktop (or in Start) and right click on it.
Click "Properties"
On the tabs at the top, click on "Hardware"
Click on "Device Manager"
Click the plus sign beside "DVD/CD ROM drives"
Double-click on Lite-On
On the tabs at the top, click on "Properties"
At the bottom, there is a box that is most likely checked that reads...
"Enabled digital CD audio for this CD-Rom device"
Uncheck it.
Do the same for all DVD/CD Rom devices you may have.
This simple solution worked for me. Now both my DVD and CD Roms are reading all of my cds.
I would suggest trying this simple step first before downloading any drivers or buying any 'Driver Update' programs - which may cause you even more problems than you are already having.
Beth
Lite On LiteOn... • Answered on Sep 22, 2010
Try downloading eusing registry cleaner.
Its free and once it's done, restart your computer and put the drive back in.
Lite On LiteOn... • Answered on Aug 07, 2010
Check for loose contact, dry solder at the power connector end, try cleaning the lens, most of the times the rubber belt that is used to drive the tray gets loosened due to time factor and usage
Lite On LiteOn... • Answered on Jul 29, 2010
Lite On LiteOn LH-20A1P - Disk drive - DVD±RW (±R DL) / DVD-RAM - 20x/20x/12x - IDE - in Burner Logo
64 questions posted
Top Lite On Computers & Internet Experts
Vernon Taylor
ray gallant
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lite On Computers & Internet
Most Popular Question
lite dvdrw
  • Computers & Internet
