20 Most Recent Optimus 12-1978 Seven Band Stereo Graphic Equalizer/sub Woofer Questions & Answers
I turn my receiver on then it says "powering off" right away everytime i turn it off. I hope you can help. thanks
Looks like a rebadged Pioneer if it is, one of the output channels has probably been damaged and it shuts down to protect the rest of the system. Time for service at your local HiFi dealer.
2/23/2024 6:48:05 PM • Optimus Audio... • Answered on Feb 23, 2024
How to hook Optimus stav 3770 to tv
well mixing old AVR with newer TV (non told) or the reverse does that,! early AVR (mines packed in box attic) has no digital ports only has RCA analog and no hdmi ports. (retired it ,just like me) see there, that is progress. (1/2 joking) just looked at 3770 is all analog a sea of white/red/yellow RCA jacks on the rear.. OLD tech. no TV told but the the best TVs like LG and SAMSUNGS have both. analog and HDMI digital jacks. mine does. LG55xxxxxx there are only 3 choices new AVR, (best choice with a future) buy older TV (hah) buy LG with both on the rear. se this? D = digital A = analog RCA pin jack inputs. video and audio too. a far better TV has both not just HDMI. tv-undefined-undefined-0_0.jpg
8/16/2022 12:17:25 PM • Optimus Audio... • Answered on Aug 16, 2022
Need a replacement remote for Optimus STAV-3770 audio/video receiver
google Optimus STAV-3770 remote several offers on line. eBay has several starting at $6.00
3/17/2022 5:11:21 PM • Optimus Audio... • Answered on Mar 17, 2022
2answers
I recently bought a optimus stav 3350 reciever and the left side channels on both a and b speakers has a static distorting sound coming from it used more then one set of speakers to check, I inspected it and there are 3 transistors I believe they are small black box looking things that are round with one flat side that has dark burn marks around them on the board the are in, could that be the problem and what else could cause this? Thank you for any advice you can give
It is possible that the solder connections on those transistors are bad and need to be re-soldered. This is common with components that get hot. I would also check any capacitors that are close to them since heat can dry out the capacitors. Other than that, it could be a number of other things.
2/15/2022 10:43:39 PM • Optimus Audio... • Answered on Feb 15, 2022
Optimus stereo wont power up
  1. Verify the Unit Isn't in Protect Mode.
  2. Check the Fuses.
  3. Check the Pigtail Connector.
  4. Check for Power at the Head Unit.
  5. Check for Ground at the Head Unit.
  6. Bench Test the Head Unit and Replace if Needed.
4/18/2021 1:46:37 PM • Optimus Audio... • Answered on Apr 18, 2021
How do I program preset radio stations on an optimus stav 3450
this should work on your model
2/17/2019 5:03:53 PM • Optimus Audio... • Answered on Feb 17, 2019
0answers
0answers
I need a remote to go with optimus 32-1163 mmanufactured in 2000 karaoke machine
http://www.amazon.com/OPTIMUS-Replacement-Remote-Control-12070397/dp/B009H5LWKG
9/29/2018 5:10:25 PM • Optimus Audio... • Answered on Sep 29, 2018
How do i get my optimus sta-3180 receiver out of stuck in standby mode
I found the plastic button plunger on the front becomes too short to actuate the tiny on/off switch inside. Remove the cover and insert a piece or two of thickish paper (like file-folder thickness) between the plastic plunger and the switch. Let it hang back over the circuit board so it will stay in place.
5/22/2018 1:34:52 PM • Optimus Audio... • Answered on May 22, 2018
0answers
Optimus 12-1978 Seven Band Stereo Graphic Equalizer/sub Woofer Logo
0 questions posted
Top Optimus Audio Players & Recorders Experts
NOEL
NOEL
John
John
ADMIN Andrew
ADMIN Andrew
Are you an Optimus Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Optimus Audio Players & Recorders
Most Popular Question
service manual optimus sta 3190
  • Audio Players & Recorders
