20 Most Recent Whirlpool Gold Black-on-Black 25.4 cu. ft. Side-By-Side Refrigerator w / Accu-Chill Temperature Control System GD5SHGXLB Questions & Answers
Water leaking from water filter housing
if water is leaking from where water line is try cutting the very end off water line and reinstall water line... if it is leaking any where else replace housing
10/10/2014 2:27:51 AM • Whirlpool Gold... • Answered on Oct 10, 2014
How to remove hoses on water filter housing
this is hard to explain but here goes..... push the water line in and at the same time push the flange in as well... this will realese the water line, holding inwards pressure on the flange pull the water line out of filter housing... I know this sounds confusing, but when you look at housing it will make more cense.... hope this helps........ ken
10/10/2014 2:24:51 AM • Whirlpool Gold... • Answered on Oct 10, 2014
Water leaking from hose on water filter housing
shut water off to ref and try cutting the end of the tube off, but only 1/8 to 1/4 of an inch.. insert back into housing firmly and turn water back on and see if leak stopped.... if still leaking order and replace the filter housing..... hope this helps....... ken
10/10/2014 2:10:25 AM • Whirlpool Gold... • Answered on Oct 10, 2014
Freezer is not working and i hear a clicking noise
Hi there Is water running. Or is there no activity in freezer? Kolbrun
6/23/2012 3:24:26 PM • Whirlpool Gold... • Answered on Jun 23, 2012
Whirlpool Gold Refrigerator making frequent
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/18/2011 4:20:27 PM • Whirlpool Gold... • Answered on Aug 18, 2011
It sounds like a bowling ball rolling around inside the fridge.
Sounds like maybe one of the mounts for the compressor might be bad. The compressor is around the size of a bowling ball and does need the vibration dampened to stop noises like that.
7/27/2011 3:13:29 PM • Whirlpool Gold... • Answered on Jul 27, 2011
Model GD5SHAXMB00. The digital temp numbers are
check the pcb board then locate busted fuses replace it then after reset theres nothing happen possible your pcb damage need replacements.
3/28/2011 12:05:03 PM • Whirlpool Gold... • Answered on Mar 28, 2011
The freezer nor the refrigerator
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
2/1/2011 10:55:39 PM • Whirlpool Gold... • Answered on Feb 01, 2011
Icemaker overflows water
Good day,
If it is erratic as you describe and replacing the ice maker twice has not resolved the issue it would make sense to replace the water valve in the back rear of the machine, if it hasn't been done so yet. It's the flakiest part of the system and has the highest failure rate. It's been known to fill too little, to much, and sometimes not at all.
5/26/2010 5:55:04 PM • Whirlpool Gold... • Answered on May 26, 2010
My ice maker isn't working anymore
Here is a tip that I wrote that will give you some things to try...
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
4/9/2010 2:11:58 AM • Whirlpool Gold... • Answered on Apr 09, 2010
My indoor ice maker quit making ice. what can i do
why not call an expert to examin it and fix it 4 u
4/8/2010 12:06:42 AM • Whirlpool Gold... • Answered on Apr 08, 2010
My fridge quit cooling, a friend told me to
Can you let me know when your fridge stoped working does your fa in freezer still run?Or is the fridge stone dead?Also what make is it?
3/13/2010 4:37:39 AM • Whirlpool Gold... • Answered on Mar 13, 2010
Water tube is frozen to icemaker, do i have to
Good day,
As a rule yes. The basic reason is the valve is leaking slightly on the off cycle. It dribbles down the fill tube when the ice maker is not cycling causing this problem.
It might be noted that on some models engineers have designed a fill tube with an aerator slot to help offset this problem.
It is new, and you might want to take the model number and check with your supplier to see if one is available for your machine.
3/6/2010 5:32:01 PM • Whirlpool Gold... • Answered on Mar 06, 2010
Indor ice maker water tube is frozen
If it is frozen, you will have to empty the food from the freezer, open the door and leave it open at least over night. I would doubt that it is frozen. I would suspect the water valve at the back, bottom of the fridge.
3/3/2010 10:50:11 PM • Whirlpool Gold... • Answered on Mar 03, 2010
Refrigerators Logo
Popular Tags
42 questions posted
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
water leaking from hose water filter
  • Refrigerators
