20 Most Recent Samsung SpinPoint P120 SP2504C 250 GB SATA II Hard Drive Questions & Answers
there is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Samsung... • Answered on May 02, 2015
Replacing the hard drive involves the following process:
  1. Turn off and unplug the computer
  2. Remove the two screws from the left panel (facing the front of the tower)
  3. Slide the left panel back and to the left to remove it
  4. Unplug both power and data from the hard drive
  5. Unscrew the hard drive (You may need also remove the right panel to get to additional screws)
  6. Slide hard drive out
  7. Slide in new hard drive.
  8. Screw in new hard drive in approximately the same fashion as previous hard drive was screwed in
  9. Plug in power and data
  10. Re-install panel
  11. Plug computer in and boot
However, if this is your main or only hard drive, you will need to install your Operating system and all of your software and files from scratch. It may be possible to preserve them, but that's often risky and requires a bit more work. If this is your main hard drive, you probably want to consult an expert on having the old drive contents moved to the new drive.
If you like my solution, please vote for me,
Samsung... • Answered on Apr 09, 2011
ebay maybe?
Samsung... • Answered on Mar 10, 2011
This is in an HP PC? This error (like most SMART errors) is indicative that your disk is on its way out. Your best bet is to buy a new disk quickly, and get important information off this one! SMART errors are usually fairly accurate, though occasionally disks go on for years.
(SMART = System Monitoring And Reporting Technology)
Samsung... • Answered on Jul 12, 2009
try downloading any program that manages disks (partition magic for example ) and see if all the space appearsin that program, if so asign to that space a drive letter and format it .... (with the program that u will use )
Samsung... • Answered on Jan 23, 2008
To download songs just go to the website from where u want to download song then there should be download button around a song to download.Just click on it and your download starts.
thanx
Samsung... • Answered on Mar 31, 2021
1 Turn on the computer, then press the F4 key several times before the Samsung logo appears to open Samsung Recovery. 2 Click Computer Factory Reset 3 Click the Start Factory Reset button. 4 When the Start reset confirmation screen appears, click OK. 5 Your PC is reset. (Please note: resetting may take some time, depending on your PC.) 6 When a message appears saying reset is complete, click the OK button. 7 The PC will restart. 8 Finish setting up your PC according to the on-screen instructions. 9 After rebooting, check that your PC has been reset correctly.
Samsung... • Answered on Mar 27, 2021
Do you have a recovery CD or DVD that came with the unit? If so, try booting up from the cd and perhaps it will let you run a repair? Of if you can get into the BIOS of the unit, and that may be hard if your keyboard doesn't work, see if there's an option to activate the keyboard before bootup. Another idea is plug an external USB keyboard in and see if that works after a reboot.
Samsung... • Answered on Mar 08, 2021
check junk folder , check spam folder smart tv uses what system ? google android ? download app to tv from playstore if android system ??
Samsung... • Answered on Feb 12, 2021
Does this all-in-one have the original Windows 7 installed or has the OS been upgraded? This could be a driver issue or a problem with the Ethernet cable (if you are using the wired network). It could also be caused by the distance/direction between your computer and the router, if you are using the wireless network adapter. Try a new cable. Open the Device Manager (right click on Start for all versions of Windows). Find the section with the network adapters and check for entries with a yellow triangle with an exclamation point or red triangle with an x. These indicate the driver that has an issue. I recently went through some trouble-shooting on a slow computer running Windows 10 2004. After checking everything with the drivers, including launching the system in Safe Mode with Networking, I finally found the Blue Screen of ***** that the user didn't mention. The Windows Driver Verifier was causing crashes. The solution turned out to be using the sfc /scannow command at the command prompt when run as administrator. (Again, use right click on Start for a fast option to find the command prompt.) On one laptop (with OS updates from Windows Vista, Windows 7, 8, and 10) I dealt with, Microsoft installed a driver for the wireless network under Windows 10 that just didn't work. It would make the wireless network slower than the 10/100Mbs wired network adapter. Every time I did a clean install, I had to specifically install the correct Broadcomm driver for the wireless network adapter. I made a point to save this driver to a CD so that I could speed up restoring the network functions before Windows tried to do any updates. I hope this helps. Please add a comment with more information about the OS on the DP700A3B-A02US and the internet connection type that you are using. If you see any error messages or had any system crashes, add any key words that you saw. Then I can better assist you in solving the problem. Cindy Wells
Samsung... • Answered on Oct 20, 2020
Resolve the issue of Error Code 0xc0000185 with the help of the Hp Technical Support Phone number. Here the Technical Expert will provide you all possible help for getting out of this issue. Just visit the help website through the link shown below. Link:- https://www.hptechnicalsupportphonenumber.com/blog/fix-hp-printer-error-code-0xc0000185
Samsung... • Answered on Sep 11, 2020
there is a TP link that you can get from places like Jaycar that will turn your house wiring into extension cords for the router the operation can be explained at the shop but it means that you can extend the wires to any part of the house and by using ethernet cables will connect other computer, printers and tv units easily cheaper that new modems and routers
Samsung... • Answered on Jul 14, 2020
Well... Yes and No... Does this set have an Ethernet port? If so then try and plug it in that way. Try and reset the router and tv Make sure the connection settings are correct or defaulted Are you entering the correct password? Are you close enough to the router? reset the network setting on the tv it's possible you may have a bad wifi chip but im not thinking you do. Good Luck and come back it the above does not help we can go more into detail. Mr.Mike
Samsung... • Answered on May 20, 2020
Download and install this it will allow almost all media to play in your windows media player.
http://download.cnet.com/K-Lite-Codec-Pack-Full/3000-13632_4-64246.html?tag=mncol;2
Or you could download VLC media player, it plays everything.
http://download.cnet.com/VLC-Media-Player/3000-13632_4-10267151.html?tag=mncol;1
Personally I would stick with the windows media player, just because it's half a part of windows, & it's what I've always used. Or if you have a zune, or xbox windows media player is needed.
Samsung... • Answered on Apr 28, 2020
Samsung SpinPoint P120 SP2504C 250 GB SATA II Hard Drive Logo
Popular Tags
8 questions posted
Top Samsung Computers & Internet Experts
Jean Thiebaux
Jax Planet
Jax Planet
aliasger yq
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Spinpoint Samsung
  • Spinpoint Samsung
Most Popular Question
dell pc scan says
  • Computers & Internet
