20 Most Recent
Rockwood XR-3973 Car Audio Amplifier Questions & Answers
I have two 12' kickers,
It all depends on the wattage of your subs. you need an amp more powerful than the both subs combined. For example. for 2 500 watt subs, you'll need at least a 1200 watt amp. amps should never be truned up to full power, 80% max as they tend to blow more quickly and overheat when on max. ideally you want an amp over the total combined wattage of your both subs so you dont need your amp on max for the best sound for you subs.
Whats the RMS on my 1000watt 4ch amp???
hi
Ive done some research and i haven't found any conclusive ending however the best i can do is tell you the round about RMS which is approx 200 to 150 unbridged.
Can i hook it up to my home sound system
You must connect the amp to a power supply capable of 12VDC at over 30 amps and either have built-in current limiting capability or install a fuse in-line with the power wire.
