20 Most Recent Philips DVDR3435V/37 DVD Recorder/VCR Questions & Answers
There is a part that is called an idler wheel assembly that is critical for play, rewind, and fast forward, and may have stopped working. The second possibility is that the drive belt that runs the idler assembly has broken or come off.
Philips... • Answered on Jan 01, 2011
try following codes
RCA universal remote controller:
021, 022, 062, 096, 124(VCR)
162, 356, 357(DVD)
Philips Magnavox Universal Remote PM335
130 226 330 536 631 734 738(VCR)
441 442 943(DVD)
many direct codes doesn't work ,code searching method all ways work better but irritating
STEPS:
1. Press and hold CODE SEARCH
until the INDICATOR LIGHT
lights, then release CODE
SEARCH.
2. Press and release the device
button for the device’s code
you are retrieving (TV,VCR or
DBS•CABLE). The INDICATOR
LIGHT will blink once then
remain lit.
Note: For AUX, press DVD•AUX
then the device button for the
code you are retrieving.
3. Press and release CODE
SEARCH. The INDICATOR
LIGHT will turn off.
4. Starting with 0 on the keypad,
press the number buttons in
order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the
INDICATOR LIGHT to blink is
the first digit of your code.
6. Repeat step 4 until you have
retrieved all three numbers in code
NOTE
if any of the above works note down code used in small bit of paper and place it in the battery chamber(safe place)
Philips... • Answered on Jun 14, 2010
E2 Is a code indicating that the tape chassis is locked in the eject position. You may want to have a look at the mechanism to be sure nothing has been bent or jammed - it should move freely when a tape is inserted.
The error codes for the Mitsubishi VCR's are as follows:
E1 - Loading motor lock in the load direction.
E2 - Loading motor lock in the unload direction.
E3 - Drum motor lock.
E4 - Reel lock detection.
E5 - Video envelope detection.
To reset error message - It will be done automatically after repaired or press VCR power switch for more than 8 seconds.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Philips... • Answered on Apr 22, 2010
I went to the maker of the Cogeco Atlas DVR 5 Device and typed in the make and and got the codes 1 for VCR and 1 for DVD.
Philips... • Answered on Jun 25, 2009
Connect converter box to your DVD/VCR player at the ant in. Depending on your location you might need a new ant for UHF.
Philips... • Answered on Jun 15, 2009
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Philips... • Answered on Jan 27, 2009
I found that part #T5B was on the bottom of the VCR tape tray on the right side of the VCR tape bay opening and was spring activated by inserting the tape to allow the tray to retract into the player mechanism. Without a tape installed, part T5B prevents the tape carriage from retracting.
However, I still couldn't get the whole mechanism timed properly, and gears were skipping teeth, the mechanism was still binding, and shutting the power for the whole player down. Therefore, I removed the rubber drive belt that operated the VCR tray insertion/ retraction process, and disabled the VCR side from operating at all. This allowed the power to remain on and allow the DVD side to work properly.
This worked only for the Phillips DVP3150V/37. I cannot say for certain if other Phillips players are the same.
Philips... • Answered on Oct 14, 2008
Check that the clock on the machine is set to the correct time and date. Check am/pm.
This problem is usually caused by incorrect time & date.
Philips... • Answered on Apr 02, 2008
Not really, these VCR tapes that are copyrighted from the store are highly secured. So you can not dub them actually.
Philips... • Answered on Nov 18, 2007
Try 606 or 616 one of those should work.
Philips... • Answered on Mar 06, 2021
It could be because the TV's screen is starting to go bad and that your TV's screen and TV are starting to die on you.
Philips... • Answered on Feb 14, 2021
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty. Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Philips... • Answered on Feb 11, 2021
Philips DVDR3435V/37 DVD Recorder/VCR Logo
17 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
vcr shuts off after
  • Televison & Video
