20 Most Recent Sony VAIO VGN-N220E/W Notebook Questions & Answers
You should not change this. Laptops have small video chips and often depend on "shared" memory to achieve good performance without overheating. Basically, the video processor borrows some of your installed RAM memory. Also, your laptop may have been supplied to you with less total RAM memory than the maximum and you can add more memory. In Windows, click on Start then right-click on Computer and select Properties. In the Properties window you can read how much total memory is installed. 2GB (2048MB) is a desrirable amount for Windows XP. Windows Vista and Windows 7 can benefit by having total 4GB of RAM memory. Check your Sony user manual for instructions on adding more memory. Basically, you turn off the laptop, remove the battery pack and unscrew a small cover on the bottom of the laptop to access the memory slots. Usually, there are 2 slots here. Ideally, you should install a matched pair of memory modules (a "kit") for peak performance. However, quantity of memory is more important than having matched modules, so if one slot is occupied and the other slot is empty you may simply buy one more module and install it in the empty slot.
Sony VAIO... | Answered on Feb 02, 2015
Get the product name and model of the webcam,
Go to www.google.com and type free download of xxx mebcam driver.
You can also visit www.driversguide.com for free downloads.
Sony VAIO... | Answered on Nov 07, 2013
Do a System Recovery?
Sony VAIO... | Answered on Sep 24, 2013
You can't v is for virtual which means 64 is your graphics ram and the rest is borrowed from your hdd
Sony VAIO... | Answered on Aug 19, 2013
when the partition running out of space, cleanup is just a tempory solution. To sove this problem, you need to enlarge the insufficint partition space. http://www.disk-partition.com/resource/free-partition-magic-for-windows7.html
Sony VAIO... | Answered on Dec 13, 2012
If memory serves me, the mass storage controller is part of the chipset software. Here is a link to the driver download for you laptop. Choose the OS, and then look under motherboard for the chipset driver. While you are there, you might even update all your hardware drivers.
http://esupport.sony.com/US/p/model-home.pl?mdl=VGNN220EW&template_id=1&region_id=1&tab=download#/downloadTab
Hope this helps
Sony VAIO... | Answered on May 18, 2012
Hope this helps
Sony VAIO... | Answered on May 15, 2012
The light indicates that the radio for wireless internet access has been turned off. On my Sony the light is on the right hand side nearest me. It is green in color. The on off switch is on the left hand side next to the headphone and microphone jack. Yours may be different but somewhere is an on off slide switch. So explore the sides and back till it is located
Sony VAIO... | Answered on Jan 14, 2012
Unlockbiosrecovery.com can unlock your bios password for only $20 and they guarantee it to work. Great service and fast.
Sony VAIO... | Answered on Oct 03, 2011
There are many ways to connect your Vaio to a Bravia. If you have a router, you can connect both pc's to it using ethernet cable (cable that looks like a telephone cord but a little bigger). Then open your control panel and click on networking. then follow the prompt to create a home network to allow both pc's to share files.
You can also connect to the Bravia using remote desktop through the internet. The easiest way to do it is to open the internet and type in join.me.com in your search box to locate their website. Then open it. You will see "share" on the left side in orange. Click on the orange arrow. The site will install a small file and then give you a nine digit number on the top of your screen. Have the other computer go to the same website but instead of clicking on "share" you click on "join" on the right side in green instead and then enter the nine digit number into the box and press your enter key on your keyboard.
You should be able to see the Bravia's computer screen. If you want to control the Bravia computer using your Vaio, click on the picture of the mouse at the top of the screen while in join.me and it will send a request for permission to the Bravia to control the mouse and access the files on it. The Bravia approves the request and then you can move and control their mouse.
Sony VAIO... | Answered on Sep 22, 2011
take xp cd and repair you system
Sony VAIO... | Answered on Aug 25, 2011
Hi mproulx,
It is required to install the Wireless LAN Utility Update and Wireless LAN Driver Update in the Computer to fix this issue.
Here are the link to download the Updates.
Intel Wireless Network Adapter Driver Update
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN220EW&upd_id=4751&os_id=28
Wireless Switch Setting Utility Update
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN220EW&upd_id=2970&os_id=28
Please download and install the Updates in the Computer. Also please restart the Computer after each installation for the settings to take the effect. This should fix the issue with the Wireless.
Good Luck!
Hope this helps.
Please post back if you require further assistance.
Thanks for using Fixya.
Sony VAIO... | Answered on Oct 20, 2010
Had the same issue, couldn't find a solution on-line, but I figured it out. First remove the battery and the screws underneath it. Then remove all the screws on the bottom of the laptop. Remove the optical device and remove the 2 or 3 screws holding the bezel to the base.
Here's where it gets tricky. There is one more screw under the keyboard, right where the F6 key is. Can't get to it until you remove the keyboard, but there is no obvious way to remove the keyboard.
Pry the case apart a bit and look inside, there are two plastic release cllips that hold the keyboard in. Very carefully retract these clips and remove the keyboard. Then you'll see that last screw. Take it out and you can slide the top bezel out of the way without removing the touchpad cable.
Replace the hard drive and put it all back together.
Hope this helps
Stillwater Computer
Sony VAIO... | Answered on Apr 06, 2010
If you have previously registered the software or have a proof of purchase for the software, contact the manufacturer and they will provide you with a new product key.
FixYa and it's experts do not provide product keys, serial numbers, illegal software, authorization numbers or codes, warez, hacks or cracks under any circumstances. Any expert that does so will be barred from answering questions. Those asking are subject to their membership being deleted and be barred from the site.
Thanks for using fixya
Regards
PCmania
Sony VAIO... | Answered on Apr 05, 2010
most sony laptops either have the hard drive internal and either access is via a back plate with a few screws underneith or you have to undo all bottom screws then were the track pad is the top borrom half with either come away reveling the hard disk or the complete bottom will come away.
Sony VAIO... | Answered on Feb 11, 2010
Battery most likely has dead cells, the live cell that is still working is showing 100% but does not enough juice to keep the computer running by itself. You need a new battery.
Sony VAIO... | Answered on Jan 07, 2010
they do make ****, and its expensive to replace any of thier parts...you have to replace it, but if you search by make of laptop usually you can find a comparable one for cheap. may be out of a different sony or a different brand but if its the same num it will work
Sony VAIO... | Answered on Sep 02, 2009
Sony VAIO VGN-N220E/W Notebook Logo
Popular Tags
43 questions posted
Top Sony Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VGN Sony
  • VGN Sony
Most Popular Question
remove hard drive
  • Computers & Internet
