20 Most Recent Zenith XBR616 Questions & Answers
no easy way to do this unfortunately. You either need to connect your VCR to a DVD recorder and record it directly onto DVD or use a device such as this http://www.dx.com/p/easycap-usb-video-capture-adapter-5707 to connect your VCR to your computer and record it onto your computer that way.
Zenith XBR616 • Answered on Feb 23, 2015
1 800-243-0000 e mailed mine to me but unit will not work
Zenith XBR616 • Answered on Mar 08, 2013
This thing is a piece of ****
Zenith XBR616 • Answered on Sep 29, 2011
You are not alone...Some DVD players wont read the DVD s and
then it show no disc..
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc has problem laptop does not read either..
if your set has still under warranty ,consult to service they may replace the LASER EYE.. ("cross your finger ! " )..most of the time Laser Eye malfunctions...
Just in case,quick remedy ,I recommend to buy a "wet DVD/CD laser cleaner " from any store.it is available at Electronic Stores ..And clean the laser eye at least twice..
YOUR DVD itself should be clean and finger prints free as well....
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Zenith XBR616 • Answered on Jul 01, 2011
Same problem with the same model unit
Zenith XBR616 • Answered on Feb 14, 2010
check either smps damaged or find if ur pc shutdown at a spesific time
Zenith XBR616 • Answered on Nov 19, 2009
what tv connection are you using from the dvd make sure connection are fully pushed in, try another dvd player with the same tv and connections.
Zenith XBR616 • Answered on Aug 25, 2009
YEAH I THINK ITS BOUTLEG
Zenith XBR616 • Answered on May 25, 2009
You need the cables to hook your VCR to your PC and also a decent Video program that allows you to import a file (The Videotape recording) to the program, and burn it from there.
Zenith XBR616 • Answered on Nov 27, 2008
You need the correct codecs on your computer.
K-Lite Codec Pack contains codecs for many video formats...
Zenith XBR616 • Answered on Sep 26, 2008
its the close/open button, it is stuck . unstuck it by playing with it or by opening your unit.
ynx 4 using fixya,
drcool
Zenith XBR616 • Answered on Sep 13, 2008
A common practice in the TV industry is to include the size in inches in the model number. Often, a model will be made in different sizes, for example, z42pj240 may have a z50pj240 family member. They will use the same main circuit boards and remote controls. Check the list in your universal remote control manual for a variant like that.
Zenith Televison... • Answered on Mar 29, 2021
If you are trying to use the player and switch between DVD and VCR there is usually a button on the front of the player and a matching one on the remote. VCRs are becoming very rare now so most TVs don't have the connectors for them. How old your TV is will control how you do this. Older HD TVs are fitted with a SCART connector, ( a large, chunky, rectangular connector with lots of pin holes), or RCA connectors, (3 round pin connectors coloured red, white and yellow). *Note* Make sure you use the 'OUT' connectors on the VCR and the 'IN' connectors on the TV. Some newer TVs will let you connect through a 'screw in' Satellite/'CABLE TV wire connector.
Zenith Televison... • Answered on Nov 20, 2020
1) tune the desired station frequency
2) while the frequency is being displayed, quickly press the memo set/clock adjust button.
3) press the desired preset button
4) press the memo set/clock adj button again
5) the station will be stored
Zenith Televison... • Answered on Apr 24, 2020
To set the Alarm press the Alarm Set button then use the set buttons on top change the Alarm time. Use the to change the Alarm time, when the Alarm time is set press and hold enter until you hear a beep. Press the Alarm On/Off button to select radio or buzzer for the alarm or alarm off. http://portablemedia.manualsonline.com/support/zenith/clock-radio/zenith-1233a-how-do-you-set-the-time-on-the-clock-4514622
Zenith Televison... • Answered on Apr 23, 2020
Zenith XBR616 Logo
18 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
convert vcr dvd
  • Televison & Video
