20 Most Recent Samsung SyncMaster 305T 30 in. LCD Television Questions & Answers
Samsung SyncMaster 305T marbled green and blue screen
Videocard, obviously
1/22/2018 8:08:23 PM • Samsung... • Answered on Jan 22, 2018
0answers
Monitor flickering, darkness, slow response
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
4/18/2017 1:21:06 PM • Samsung... • Answered on Apr 18, 2017
Having issues with my samsung
since no one answered this, I had the same issue, It was pretty basic but when nothing is connected to the screen (the DVI cable is not connected to any device) it loops in red green blue and white. So just connect something to it and it should work. This monitor is not the most practical since it has no menu and just 1 port.
11/5/2015 8:06:52 PM • Samsung... • Answered on Nov 05, 2015
Driver sysncmaster 305t win7
Visit Samsung official website. Gopakumar Gopalan Google
8/12/2014 8:19:54 AM • Samsung... • Answered on Aug 12, 2014
0answers
My samsung monitor all of
Remove your HDMI cable from the Cable box, replace it with Component Cables. Do not use HDMI with Cable.
Normally if everything is green using component cables it would be because the Red/Blue cables are not fully inserted somewhere either on the display or on the source device. But since when you turn it on, with no source connected at all and it is green it sounds like it is a defective TV.
TVs in the world and here is another fine example of there quality work. This is a firmware problem that the LG engineers should know about. Contact LG and inform them of this problem. Maybe they already have a firmware update for your TV, if not, then they need to start work on this issue.
I have been racking my brains trying to fix my boyfriend's new Samsung TV which gets the dreaded "green screen." Being a former PC Tech I knew there had to be a work around.The issue seems to be an incompatibiity with the receiver and cable box which sees it as a repeater.
Today I actually found it by accident fooling around with the cable tv box settings. BTW it is a Motorola Cable box.
This went all the way to the Engineer who had no solution as you all have experienced.
Here is what I did...
Turned off the Cable Box and pressed the menu setting on the remote till a white screen popped up.
Scroll down and disable the overide settings turn to off
Then scroll down to additional hdmi settings and hit enter
Change it from hdmi to dvi
Then exit and turn your cable box back on
Your screen will flicker a bit and then focus back to normal
Now try changing your channels from sd to hd it should be fixed.
All TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables.
If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen.
Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens.
The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them.
4/14/2014 12:29:06 AM • Samsung... • Answered on Apr 14, 2014
2answers
The screen flickers badly.
Now try looking at the probable source of the problem.
Not the backlight or inverter or power supply, But the controller card on the lcd panel.
I repair these.
ebay's bammbammfran
4/14/2014 12:25:40 AM • Samsung... • Answered on Apr 14, 2014
Samsung SyncMaster 305T One-half of the
This problem is, as you suspected, almost certainly a problem with your monitor's backlight.
However, there are a number of possible causes for a backlight problem besides a bad fluorescent bulb. The bulb must receive a good supply of power in order to operate and that power is controlled via a number of circuits.
By far the most common cause of backlight failure is a problem on the POWER SUPPLY circuit board. Poor quality components, overheating, or just old age will lead to component failures on the power supply circiut board, usually starting with the electrolytic capacitors. Bad capacitors are sometimes obvious to spot in that they are often scorched, have bulging tops or are leaking dark gunk from the inside. However, also be aware that some failed components have no outward signs at all.
If you are handy with a screwdriver and have a basic knowledge of electrical safety precautions, then you can just disassemble the unit and replace the power supply board yourself with a new one from EBay. Here is a link to one that is available for your model:
http://cgi.ebay.com/SAMSUNG-305T-Power-Board-BN96-03938A-/270693008629?pt=LH_DefaultDomain_0&hash=item3f068f84f5
Just stay away from ay that say AS IS in their description of condition, this is EBay-speak for broken. Make sure it says TESTED WORKING or something similar in the desription and you should be OK.
If you are really handy with a soldering iron, you can actually order just the capacitors and replace the components yourself. Here is a link to a good supplier of repair kits for that model of monitor:
http://cgi.ebay.com/Repair-Kit-Samsung-305T-LCD-Monitor-/330499791296?pt=LH_DefaultDomain_0&hash=item4cf35299c0
The problem could also be with the INVERTER CIRCUIT but most often those types of failures will not be intermittent as you describe.
Good luck.
Joe.
4/14/2014 12:20:55 AM • Samsung... • Answered on Apr 14, 2014
0answers
My samsung monitor 305t can
You're either using a single link DVI cable (you need a dual link DVI cable for 2560x1600 resolution), or your video card doesn't support dual link DVI (which is required).
11/18/2010 10:58:42 PM • Samsung... • Answered on Nov 18, 2010
0answers
2answers
Having issues flashing screens on
It is not the lcd panel.
It is probably in the video input board (also called a logic board)
It is going through the colors while it is trying to locate a signal.
First, try restarting the computer with the monitor on.
If that does not work, try a different dvi cable .
Fran
4/24/2010 2:39:26 AM • Samsung... • Answered on Apr 24, 2010
Missing cable channels
You need to contact your cable service provider about this, it is a signal issue not a TV issue.
4/25/2017 9:55:47 PM • Samsung... • Answered on Apr 25, 2017
My Samsung 52 inch LCD screen color has changed to red, meaning when you have cable box off the what used to be solid blue screen is now red. All pictures are in red hue also. I've reset the menu to
Sounds like a coluour has stopt working and you will have to go to the repairman to get it fixet. Cheers
12/18/2014 6:40:12 AM • Samsung... • Answered on Dec 18, 2014
Samsung SyncMaster 305T 30 in. LCD Television Logo
21 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
SyncMaster Samsung
  • SyncMaster Samsung
Most Popular Question
samsung syncmaster 305t one half
  • Televison & Video
