20 Most Recent HP Deskjet 2460 Printer Questions & Answers
How to install Printer
Follow these steps to install the downloaded software.
  1. When the download is complete and you are ready to install the files, click Open Folder , and then click the downloaded file. The file name ends in .exe . NOTE: If you closed the Download Complete screen, browse to the folder where you saved the .exe file, and then click it.
  2. You can accept the default place to save the files. Click Next , and then wait while the installer extracts the files to prepare for installation.
  3. When the Install Wizard starts, follow the on-screen instructions to install the software. NOTE: If you have previously installed the software and are changing the connection type from USB to Ethernet, click Add a device when the Uninstall the software or Add a device window opens. For a Full Feature installation, you choose what type of installation you want. The following information might help you decide which installation type to use. Typical (Recommended) Minimum For full use of all your product features : HP includes valuable software to help you get the most out of your product.
    HP designed this installation type to work for most users. A custom type of installation might be available for your product. This installation allows you to install the minimum software required or the preferred software. Use this type of installation only if you have one of the following reasons:
    • The computer is low on hard disk space.
    • You attempted a recommended type of installation and received errors. (If errors occur during the recommended installation, fix them before trying a custom installation.)
HP Deskjet 2460... | Answered on Mar 09, 2013
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
HP Deskjet 2460... | Answered on Jan 22, 2013
You mean connect printer to computer .
Before connecting the cables , insert the install disc in the computer drive and follow instructions . When installation os software/driver is completed , connect the USB cable to computer and printer and power cord from printer to AC plot . Press the power button and wait for Windows to confirm installation is successfull .
You can now use yoiur printer .
Best regards ,
fanaudi .
HP Deskjet 2460... | Answered on Aug 19, 2011
Go here for the drivers
http://h10025.www1.hp.com/ewfrf/wc/product?product=2510767&lc=en
and install them in the normal way..
HP Deskjet 2460... | Answered on Jan 21, 2011
You can get the printer driver that you need from this link, just click HERE and proceed with the download.
HP Deskjet 2460... | Answered on Jan 06, 2011
Please read all instructions before you begin.
I'm going to tell you how to download a new driver. Before downloading anything from the internet, be sure that your virus control is up to date. If you are not sure, click on the icon now and open it up and find "update" and click on it and allow it to update from the internet.
>Click on this link http://www.hp.com/#Support
>Type HP Deskjet 2460 Printer in the box
>you will go to a new page with a little pull down menu
>Choose your operating system either Windows 7 32 bit or Windows 7 64 bit ( If you do not know which Op system you have, Click on Start>Right click on Computer>Click on Properties>view the info on your computer)
>Click on the correct Driver and proceed with the download.
>When asked ,save or run ,choose SAVE, then browse to your Desktop and save the file there.
>When your download is complete, follow these steps:
>Close the hp site.
>Go to Start>Control Panel>Install / Uninstall>browse the list for your old printer driver and click on it to uninstall.
>Turn off your printer and unplug it from the PC
To install the new driver:
>Turn off any running programs> check in your lower lefthand taskbar for icons and if possible pause them for a few minutes, including the internet and your virus control(in that order).
>Double click on the new driver file you just downloaded to your desktop
>It will install and may give you instructions. Just follow them and allow it to install. You may need to restart the computer to fully install it.
>If you have not been instructed to do so, you may now plug the printer back into the computer and turn it on.
>Turn your virus control back on before you turn your internet back on(!)
>Try a print. Do not delete the driver file off your desktop until you are sure the printer is working.
Note: Occasionally a download will be corrupted. If you are not successful the first time try a new download. It is important to install new software in as CLEAN of an environment as you can ( No programs running)
Please let me know if this works for you and rate my answer. Thank you!
HP Deskjet 2460... | Answered on Dec 19, 2010
Hi, hope you downloaded the right drivers, Use the below link to download .
download.famouswhy.com/hp_deskjet_d2460_printer_driver_for_windows_7__64_bit_/
Hope it helped.
HP Deskjet 2460... | Answered on Nov 05, 2010
Access the manufacturer's web-site: http://support.hp.com
and enter '2460' and do a search.
Download the device-driver for your specific Operating System.
HP Deskjet 2460... | Answered on Aug 02, 2010
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=2510767&lc=en&cc=uk&dlc=en&submit.y=0&submit.x=0&lang=en&cc=uk
HP Deskjet 2460... | Answered on Jul 09, 2010
You have not mentioned the Operating System,
Click on this below link to choose the operating system and download the drivers. Once you download and start the installation - it will prompt you to connect your printer to PC, connect it then
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=2510767&lc=en&cc=us&dlc=en&lang=en&cc=us
HP Deskjet 2460... | Answered on Jul 02, 2010
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
HP Deskjet 2460... | Answered on Jan 05, 2010
check the ink level of your printer, maybe you are low on ink or just run out, if so replace it with a genuine hp ink cartridge
HP Deskjet 2460... | Answered on Nov 20, 2009
Hey,
they are available at
Let me know if you need anything else.
Thanks,
Ekse
HP Deskjet 2460... | Answered on Feb 18, 2009
go to the www.hp.com try to serach driver there... ^^
HP Deskjet 2460... | Answered on Feb 03, 2009
from their website or in a store
It would be better for me, as far as an alert to your follow up questions are concerned if you would use the comment box below to reach me. Thanks.
In your list of ports to assign your printer to, there should be a virtual USB port.
Do you see that in your port list?
Normally, when connecting a USB printer, the software involved requires that the USB cable be unattached, and then when prompted you connect the cable. This allow the installation software creates the virtual port.
That me know about this. And please use the comment box below.
Regards,
Worldvet
HP Deskjet 2460... | Answered on Aug 11, 2008
HP Deskjet 2460 Printer Logo
26 questions posted
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
want connect new computer printer
  • Office Equipment & Supplies
