20 Most Recent Soyo GVTL3727AB Television Questions & Answers
Remote control
Does your remote have a button called TV. Press this first and then hit the power button and the TV should turn on. Remotes these days control multiple devices like DVD players and VCRs and you need to ensure that you have selected the right mode. Hope this solves your problem.
4/19/2008 1:09:37 AM • Soyo GVTL3727AB... • Answered on Apr 19, 2008
Connecting my Laptop to the Television
There is no need to select any channel on the TV to watch the video from the laptop, rather you need to select at which external source/connector the laptop is connected to. These area:
1. HDMI
2. D-Sub (HD-15)
3. VGA
4. S-Video
5. USB
6. RS-232
Often used are either the: a) VGA, or the b) S-Video. Of course likewise to be connected with the Video would be the audio out of the laptop (green) to Audio INput of the TV.
To your post of "PC audio input for", they (blue) are used to plug in any any audio source external to the PC such as a cassette deck, an analog audio from a camera, from an analog mixer and others of the same variety.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
2/9/2008 8:46:27 AM • Soyo GVTL3727AB... • Answered on Feb 09, 2008
Diagrama fps277-4f03 soyo power quemado
Diagram fps277-4f03 burned soyo power TV viore power fsp277-4f03 does not turn on I need a diagram English only on Fixya please. https://www.google.com/search?q=fps+277-4f03 make model (what is is)' and a clear question in English. https://translate.google.ca/ ..
3/20/2024 1:00:00 AM • Soyo Televison &... • Answered on Mar 20, 2024
What do I do if my 37”LCD SOYO Tv show no database it’s a 2008
That means there are no more updates for that TV. You might want to get a newer TV.
7/11/2019 2:28:43 PM • Soyo Televison &... • Answered on Jul 11, 2019
My Soyo tv volume at lowest setting on remote to loud. Is there a way to get this lower
Go to home setting on remote. Go to audio settings on tv. Adjust sound from there down to suitable level.
2/1/2019 10:56:40 AM • Soyo Televison &... • Answered on Feb 01, 2019
I have a Soyo TV you turn it on and it keeps flashing 100-0. What is wrong with it. How can it be fixed.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
12/28/2016 3:09:06 PM • Soyo Televison &... • Answered on Dec 28, 2016
Where can i find the INPUT button on my soyo mt-sygwt2697nb LCD TV
Use the remote to choose the input. You can also use the menu button to find the inputs.
9/17/2016 3:56:43 AM • Soyo Televison &... • Answered on Sep 17, 2016
My Soyo tv Mode MT-SYTPT3227AB displays black and white and no Sound how can I fix it.
If your country uses the PAL TV system make sure the TV tuner is not set to NTSC.
8/7/2016 6:49:51 PM • Soyo Televison &... • Answered on Aug 07, 2016
Soyo GVTL3727AB Television Logo
5 questions posted
Top Soyo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Soyo Televison & Video
Most Popular Question
connecting laptop television
  • Televison & Video
