20 Most Recent
Plantronics Plantronic Supra Monoral Hdset Headset Questions & Answers
We have two headsets in
The CS351N is a noise canceling headset, one of the better ones at doing
that and there is no special button to change that feature. You can try
bringing the microphone closer to your mouth and bringing the volume
down so the microphone is not as sensitive. You can try moving away from
the other user (probably impractical) or ask them to tone down the
volume.
Good luck from
Headsets Direct!
On my plantronics cs540a i do not get a beep to let me know there is an incoming call.
If your Plantronics CS540A is not providing a beep to let you know there is an incoming call, there are a few things you can try to troubleshoot the issue:
- Check the settings: Make sure that the ringer volume is turned on and set to an appropriate level. You can adjust the ringer volume using the button on the base of the Plantronics CS540A or through the settings on your phone or computer.
- Check the mute button: Make sure that the mute button on the Plantronics CS540A or on your phone or computer is not engaged.
- Check the connection: Make sure that the Plantronics CS540A is properly connected to the phone or computer.
- Check the battery level: Make sure that the battery on the Plantronics CS540A is charged and that there is enough battery power to provide a beep.
- Check the software updates: Make sure that the Plantronics CS540A has the latest software updates installed.
- Check the settings of your phone or computer, there could be an option to turn off the ringtones of the headset.
- Check the volume of the ringer, it should be set to an appropriate level.
If none of the above steps resolve the issue, you may need to contact the manufacturer or a professional technician for further assistance. It's recommended to check the user manual of your device before trying any of the above steps, as the process of troubleshooting the ringer can vary depending on the model and manufacturer.
My plantronics cs350 wireless and headset no longer beeps when phone rings
- Make sure the volume on the headset is turned up.
- Check the settings on your phone to ensure that the ringtone volume is turned up and that the ringtone is not set to vibrate only.
- Make sure the headset is properly paired and connected to your phone.
- Check the battery level on the headset. If the battery is low, charge the headset.
- If none of the above steps resolve the issue, you can try resetting the headset to its factory settings.
If none of these steps resolve the issue, you should contact Plantronics customer support for further assistance.
Audio notification issue with BT600
since re-pairing caused this, please perform another re-pair and check for the pre-sounds beeps again. I'm guessing that you might have accidentally skipped a step in your first attempt and it led to this sound occurring.
Thank you.
PLANTRONICS SG_106 BATTERY REPLACEMENT
If it is the internal CMOS battery, it should be an easy swap. There is a high potential that this will reset the radio settings and you will lose all saved channels/frequencies, and have to reprogram them. Cell size is usually a CR2032 or CR2032R. The R is for the rechargable version, but not all equipment will do that. If it isn't a black socket that you can easily pop batteries in and out of, you may have to buy one with solder tabs or wires already attached. I don't reccomend trying to solder directly on the battery because it can fail and even expload from the heat.
