20 Most Recent Whirlpool GC3SHEXNQ 23 Cu. Ft. Free-Standing Counter Refrigerator w/ Electronic Ice & Water Dispens... Questions & Answers
Means that the laser eye is not making contact with the other side. Push in the plastic flapper and see if the light goes out. If not replace the laser eyes. If it is making ice it is probably working fine. It ususlly blinks when you open the door.
Whirlpool... | Answered on Jan 31, 2011
The manual for the UW8F2CXLSB gives the normal defrost procedure. Remove food (you can set the freezer to a lower temperature or the Fast Freeze setting to super chill the food first for several hours). Store the food in a cool location. Then remove the freezer drawers and turn off the unit. Leave the freezer door open and put some towels or other absorbent cloth in the bottom to soak up the ice water. Replace the wet towels with dry ones as needed. Once defrosted, clean and dry the freezer before turning it back on. Then return the food to the freezer. There isn't a fast defrost that I know of for this Whirlpool freezer.
I hope this helps.
Whirlpool... | Answered on Oct 17, 2020
Your drain is stopped up. The water is freezing because it has no where to go. Clear the drain line with compressed air.
This board needs to be programmed google how program board for fridge i believe ve on YouTube
Whirlpool... | Answered on Oct 06, 2020
Bad control board it's on back side of the fridge
usually if u can replace all 4 or 5 capacitor on the board should solve the problem
WHIRLPOOL WRF40 Solution to this problem!!! very easy ----I assume you have a problem with the control board switching on and of erratic when you pass setting 3 on the LED display, the designers of this fridge left the calculator at home that day, ask a technician to replace the Resistors 5, 6 & 7 (330 OHM 1/4 watt) on your electronic control board with 680 OHM 1/4 watt. This would solve the problems with this board, the LEDs will not be as bright as they were but still highly visible. Questions? [email protected]
Hi Lucille,
NO This model does not have a water filter.You will need to complete disconnect the ice maker and clean it out. Then remove and flush the fill tube. If ice still appear dirty, you may to replace the water valve,the water tube and the ice maker too. I will link the parts needed and see the repair video on how to access them. https://www.appliancepartspros.com/whirlpool-whirlpool-icemaker-kit-4317943-ap2984633.html
https://www.appliancepartspros.com/whirlpool-tube-water-w10823511-ap5989588.html
/whirlpool-water-valve-4318046-ap3103466.html
Whirlpool... | Answered on Sep 21, 2020
The main control board in the back of the fridge is most likely what is wrong.
Whirlpool... | Answered on Sep 20, 2020
I think the model number is ED2KVEXVB00. Most Whirlpool appliance model numbers end in digits, not letters. SearsPartsDirect has the parts lists here: https://www.searspartsdirect.com/model/50z7if8ddb-001198/whirlpool-ed2kvexvb00-side-by-side-refrigerator-parts . Another source for the parts is https://www.partselect.com/Models/ED2KVEXVB00/ . There are probably others.
I hope this helps.
Whirlpool... | Answered on Sep 14, 2020
I realize this question was posted on 11-17-2015 if you still need help please answer the question so I may help you. Look into the freezer on the back wall to see if there is a layer of ice forming. Can you tell me what you see?
APPLIANCE 911
Whirlpool... | Answered on Sep 01, 2020
Whirlpool GC3SHEXNQ 23 Cu. Ft. Free-Standing Counter Refrigerator w/ Electronic Ice & Water Dispens... Logo
1 questions posted
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
jdthefixer
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
mean two blinks n infra red ice
  • Refrigerators
