20 Most Recent Arcam Avr300 7.1 Surround Sound Receiver Questions & Answers
0answers
I have an arcam a85 amp and now when I switch it on the volume comes on FULL and the control knob no longer works
Hi David, for what you comment, your Arcam A85, has a problem in the volume control If you have technical knowledge, you could disarm and remove the volume control, disassemble and repair it, the typical fault is that the internal contacts mounted on the shaft, do not connect with the contact wheel of the base, you have to separate, sensitively the contacts of the shaft towards the outside, so that when it is armed, make contact with the contact wheel of the base If you are not looking for a specialized technical service I hope you can solve it Greetings Franco Dosil Hola David, por lo que comentas, tu Arcam A85, tiene un problema en el control de volumen Si cuentas con conocimientos t?cnicos, podr?as desarmar y retirar el control de volumen, desarmarlo y repararlo, la falla tipica es que los contactos internos montados en el eje, no conectan con la rueda de contactos de la base, hay que separar , delicadamete los contactos del eje hacia afuera, para que cuando este armado, hagan contacto con la rueda de contactos de la base Sino busca un servicio tecnico especializado Espero lo puedas solucionar Saludos Franco Dosil https://www.arcam.co.uk/ugc/tor/diva-a85-integrated-amplifier/User%20Manual/a85p85_manual.pdf https://data2.manualslib.com/pdf2/50/4981/498031-arcam/diva_a85_service_manual.pdf?4a9d78346728f35a5c2822562f9f9a78&take=binary
6/24/2019 12:09:43 AM • Arcam Audio... • Answered on Jun 24, 2019
I have an amplifier, ARCAM AVR250. I switch it on, i see stanbye mode and a click and then 1 second after it goes back off, no nothing on screen. Transistors output good on meter.Looks like new in.
Disconnect all the cables (except power) and see if it still shuts off. If it does, there is probably internal problem. If not, re-connect speakers one at a time to determine if there's any short
3/10/2019 7:24:20 AM • Arcam Audio... • Answered on Mar 10, 2019
0answers
Arcam repair
Maybe a firmware (that's the running program) problem I'd contact Arcam, if your Solo has a USB input they should be able to send you a firmware update which you can download to a USB stick and then upload to the Solo (instructions will be in the manual). If not your local Arcam dealer should be able to do it for you Arcam warranties are 3 to 5 years. Don't now if they'll edit this but also try AV Forums online. good luck
2/16/2015 1:26:46 AM • Arcam Audio... • Answered on Feb 16, 2015
0answers
0answers
Arcam cd
Be the first to answer 1/5/2014 5:10:23 PM • Arcam Audio... • Posted on Jan 05, 2014Be the first to answer
0answers
Arcam Avr300 7.1 Surround Sound Receiver Logo
1 questions posted
Top Arcam Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Arcam Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Arcam Audio Players & Recorders
Most Popular Question
arcam a90 intergrated amp when playing
  • Audio Players & Recorders
