20 Most Recent Sharp CD-SW300 Shelf System Questions & Answers
3answers
I have a Sharp CD-SW300
Hi.
To start Try unplugging the power cord for ten minutes or so. That will reset electronics.
Regarding the fault.
If there is no display on LCD, then the controller board is probably faulty. It must be replaced, or repaired by a technician working at component level.
If the CD spins, and selector runs trying CDs one at the time, but not returning track list, then the problem is the lens.
Try using a cleaner CD, then try cleaning lens with isopropyl alcohol and QTips.
If the disk does not spin at all, then the spindle motor is faulty. The motor is tested by energizing it.
I also suggest Calling Sharp using the number listed on the owners manual. So that you will now the cost of an eventual repair.
Depending on the fault the unit may need testing at component level, and this must be done by a trained technician on site.
Regards.
11/4/2009 12:30:36 AM • Sharp CD-SW300... • Answered on Nov 04, 2009
Sharp Atomic Clock spc373 - How do I change time zone from Pacific to Central?
None of these helped. No where on the back of my Sharp SPC373 does it say TIME ZONE7783a6a7-cffe-44d1-bfd3-70fe44ddcda5.jpgI have had this clock awhile. Changed the battery. Reset 4 times. Manually changed time and it always goes back to PST
11/7/2022 6:03:47 PM • Sharp Audio... • Answered on Nov 07, 2022
I have a sharp atomic clock model spc900 and the alarm goes off every night at midnight. I don't know how to stop it.
The SPC900 has 2 alarms. On the back of the unit there is a buttion labeled "Alarm On/Off". Press the that button to cycle through the alarm on/off possibilties. On the screen you will see what alarm(s) is (are) turned on. There are4 possible settings: off (no alarms displayed), alarm 1 only, alarm 2 only or both alarms. The indicators are just above the seconds display and to the right of the big hour/minute display.
5/30/2022 8:28:20 PM • Sharp Audio... • Answered on May 30, 2022
My Sharp CD-BH950 mini component system will not change tracks on CD's. Have tried all trays and multiple CD's with no luck. It just plays the first track over and over.
Look over your player and see if a program is set. Sometimes you can set a program on the CD player to play the first song on cds. Turn program play off. It’s sometimes called delete bank where all song are skipped except first track. Or you can have the repeat button on. Turn that off. There also could be a malfunction with the player. If your still having problems reset the system.
3/22/2022 6:26:44 AM • Sharp Audio... • Answered on Mar 22, 2022
My sharp 3 disc rotary won't play past the first track on any disc
Sounds like the laser is stuck and cannot move because the slide motor has failed.
3/15/2022 2:23:55 PM • Sharp Audio... • Answered on Mar 15, 2022
Sharp model GX-CD 610 GY has error 000 what does error 000 mean
The basic binary errors are usually something small. 0000 is usually a cleaning error. I would try to clean the lens with the recommended cleaner and then try again. If problem persists the lens may be saying its dirty due to a scratch on it. These are hard to diagnose because it's a process to remove. I would clean it then replace the lens if needed.
2/23/2022 4:37:02 PM • Sharp Audio... • Answered on Feb 23, 2022
I have a Sharp CD-DH950P.. For all 5 trays I get the cannot read signal. I tried a CD disk cleaner and I get the same message.
Possible laser failure. Could be dust on the lens ... CD cleaners do more harm than good and are sold because people want them.
12/15/2021 3:23:10 PM • Sharp Audio... • Answered on Dec 15, 2021
Sharp CD-SW300 Shelf System Logo
16 questions posted
Top Sharp Audio Players & Recorders Experts
Gary
Gary
Colin Stickland
Colin Stickland
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Audio Players & Recorders
Most Popular Question
sharp cd bh950 mini component system
  • Audio Players & Recorders
