20 Most Recent
Foxconn N68S7AA-8EKRS2H nForce 680i SLI Socket 775 1066MHz DDR2-800 ATX Motherboard Retail ***Free S... Questions & Answers
Overclocking past 2.7GHz with Q6600 GO step
Please check BIOS update from mainboard manufacturer website it there has a solution for overclocking and others. Else don't push your motherboard so hard, you might get extraneous problem.
2/1/2009 10:17:55 PM •
Foxconn...
Answered
on Feb 01, 2009
I have a Alienware Aurora
You can go to the Alienware website, now owned by Dell so it can also be accessed thru Dell, and under the support section you should be able to find all system specs, compatible upgrades and any manuals you need. Hope this helps & please remember to rate my answer. Thanks.
1/23/2009 3:49:55 AM •
Foxconn...
Answered
on Jan 23, 2009
Computer wont start consistently.
Just reset ur bios settings on ur board by jumper settings or by remove the cmos battery once and once again place it in its position . start ur computer and in bios just reset all the bios settings then restart the computer
4/12/2008 12:58:08 PM •
Foxconn...
Answered
on Apr 12, 2008
N15141 drivers
N15141, is not a model is Australian elect, certs codes, a useless number.g41 is old intel chip set, 3.2GB max DDR memoryno model mobo told./ at all (sticker labels not told)no answers easy butfoxconnchannel.com is dead, now, 2012 it died.ended DIY support, we guess for ever, dead 10 years.drives for what OS, not told, xp,vista,w7 or w8?windows 7 sure.,. linux?drivers are a 3 way match.the MOBO and its chip sets , vast,The OEM makers, supportand the OS.all three must match, unless using USB or VIDEO cardsbut no OS told at all.The G41 can run w10 is some rare cases. (best CPU there)2010 or newer PCs or mobo are best not old.G41 is a 2008 chip.the VGA chip there is unknown not telling real mobo model,nor if using a GPU card, VGA.?they used many then. sorry can not guess mobo models me.
5/13/2022 12:52:42 PM •
Foxconn...
Answered
on May 13, 2022
Foxconn n15235 front panel jumpers
n15235 is not a model number everthat is an Australian, electrical safety compliance code. and 100% useless .foxconnchannel went dead 2012. they stopped dead DIY mobo sales, and the wiki said so too.the manuals are all lost now./ but googling finds some. but no model told, no JOY.lost the CD too , new in the box it had one, with PDF on CDlost that?, yes, ouch./or get the real foxconn, model number mobothe google that and add the word manualand bingo all jumpers told. some foxconn mobo are called contract OEM mobothe top makers of OEM PC ordered those custom and put them in their PC and the only clue is the lack of any DIY foxconn model on the board at all.that n15235 is NOT IT.learn to post photos of the mobo and all labels there.
5/13/2022 11:55:54 AM •
Foxconn...
Answered
on May 13, 2022
Pc h57m01a1-1.1-8eks3h
some boards are out of OEM PCs like gateways or the like
others were sold as DIY from foxconn direct sales.
did you lose the PC case?
or buy just a mobo , raw?
front panel pinouts you meant but failed to say just what:?
foxconn (channel) went dead. 2012
the maunuls where there, then, and now all gone. they are gone.
all is gone but the echo, (waybackmachine)
old
Intel P55 / H57 chipset
age ,2009, and lost manuals, are are not, lost 2012 year when the went dead.
no can find, me....
5/13/2022 11:50:16 AM •
Foxconn...
Answered
on May 13, 2022
Foxconn 2ABF Motherboard
you forgot the question1: need the manual ,a1, GOOGLE FOR IT2: NEED DRIVERS. WELL MAKER TOOK DOWN THERE DIY SITE.3: OR ?????????????their web site was taken down for all legacy DIY mobo .the exited the DIY businesstry buying only Asus.com mobo and only 2010 and newerTHE MOBO IS GOODIT IS Intel H61 BASED, I3 GEN2 UP, EVEN I7-2XXXRealtek ALC656 – High DefinitionHERE IS RETRO SITEhttps://theretroweb.com/hardware/motherboards/hp-foxconn-cupertino2W10 RUN ON THIS MOBO, SOUND MIGHT FAIL BUT IS EASY FIX. ASK
1/11/2022 3:11:39 PM •
Foxconn...
Answered
on Jan 11, 2022
Bios detection
DON'T OR SAY WHY YOU MUST?
99.9^% DON'T
OR BRICK LIKE MILLIONS HAVE NOW.
today is foxconn day;. and they went EOL , DYI in 2019
no PC told so is a vacuum of answers.
1/9/2022 11:41:32 PM •
Foxconn...
Answered
on Jan 09, 2022
Foxconn ml 94v-0 e253117 manual
94v-0 is PCB flame proof spec, certs.e253117, is outside USA, electrical safety certs, both uselessthen land on just ML.,useless too.the mobo I bet has a tag like these, learn to post real sticker tag labels only, not certs painted on the mobo we can not see.andWhat is N15235? (is and electric safety spec #)Often the marking N15235 is mistakenly deemed to be the model number of a mainboard or graphics card, but it's just Foxconn's ACA supplier code number which signifies that the product may be legally sold in Australia.
1/9/2022 11:40:57 PM •
Foxconn...
Answered
on Jan 09, 2022
Tean ml1 94v-0
Tean ml1 (94v-0)
94v0 is useless input, it is PCB burn rate test certs.
what is a TEAN?
ELO TOUCH Main Board LL050 TEAN ML1???? 2003? year?
ELO is where to go not now dead foxconn (DIY) only is dead.
ELO Touch panel. The original touch screen was 996-0484-00, PT1503NT.
its not a PC it is only a monitor
what matters is the PC not told by you nor what OS you run.
or ask ELO for them.
here they are, had to do reverse look-ups on PCB.
https://www.elotouch.com/support/downloads#/
1/8/2022 6:59:59 PM •
Foxconn...
Answered
on Jan 08, 2022
Manuel FOXCONN N15235 pour rebrancher le panneau avant merci
N15235
that is not a model, it is electrical safety certification code. useless
lost your PC casings? no PC maker names nor model told
bought a raw mobo dead? from goons on amazon. rip offs.
they sell $5 used mobo there for $100 to noobs, then why not ask the goons for your manual, oops none.
1/4/2022 4:40:03 PM •
Foxconn...
Answered
on Jan 04, 2022
Bonjour. je recherche, la fiche technique pour cette carte m? re: Foxconn ml 94v-0 e253117?
translated by Alan Turing.
Hello. I am looking for, the technical sheet for this card m? re: Foxconn ml 94v-0 e253117? 100% bogus model for sure.
your reading the wrong label.
No PC told why are you pretending it has no PC only the motherboard?????
asked 7 times here and 1 answer and all links dead now from 2010 to now.
googling for you see this. (not yours 1 of thousands)
DELL FOXCONN E253117 ML1-Y MOTHER BOARD
DELL contracted to :
FOXCONN
E253117 Elect safety coded
ML1-Y
MOTHER BOARD
94V-0 (burn rate safety PCB)
188021545A
PWB REV A00
P08D1Q9073IA00
MADE IN CHINA
SP# is HP model service part number
dell stickers show Cn_ china # or Dp;N dell part number and 3d bar code.
the key word there is DELL, it is a dell contract board
so you lost your DELL PC is that it??????????
those rear numbers are no good. use only top sticker numbers only
he HP tag is white with some a 3d bar code
and dells codes on the sticker
SP#nnnnnnnn is the right number, that works
that I tell you the real model of your Missing PC.
warning dell and hp both have mobo bottom stamped e253117
that is an electrical safety code not any kind of model at all
stop reading the bottom of the card for sure copper etched.
read the top stickers onlyh
dell sticker mobo
Optiplex 760
hp sticker
z210
learn to read the sticker tags not painted on words.
those are all real OEM service tags, just 2.
there are 12 other OEMs that foxconn makes mobo under contracts.
post photo of you mobo tags
or tell what PC it came out of and DID NOT/
1/4/2022 4:33:24 PM •
Foxconn...
Answered
on Jan 04, 2022
WHERE IS THE CMOS RESET ON A FOXCONN N15235 MOTHERBOARD PLEASE,THANK YOU MUCH
N15235 this is no model
that number is for electrical safety certification only.
post the sticker numbers on the mobo tell the true model , all of them, see SP#nnnnnn that is HP mobo
did you buy a used MOBO off the internet,just the MOBO
and no PC??????? not told that
N15235 stamp in on all there mobo every one for decades.
it means zero to you or any tech on earth this CERT
i think it is a Asian code, for sure not here USA ours is UL or RU.
here is your answer
power on and hammer Del key (if not for HP or Dell)
the main BIOS page shows now , new coin cell is a must.
then click bios default settings that resets CMOS NVRAM.
the set time and dead
then set boot order , in BIOS.
no problem stated, just nebular CMOS reset.
1/4/2022 3:53:11 PM •
Foxconn...
Answered
on Jan 04, 2022
