20 Most Recent Sigma 70-300mm f/4-5.6 DG Lens Questions & Answers
2answers
My Sigma 70-300 doesn't workin autoFocus mode. It
That lens is not an AFS type lens. The D40x camera only uses AFS compatible lenses. You could still mount and use it in M, but it will never give you autofocus or TTL flash.
6/30/2018 10:44:19 PM • Sigma 70-300mm... • Answered on Jun 30, 2018
I recently obtained a Sigma DG 70-300mm lens but do not have the user instruction manual and cannot find one on the net, how can I get one?
Hi, There is no manual for the lens. http://www.sigmaphoto.com/sites/default/files/sigma_lenscatalog_en_2014-2.pdf By the way if you would like to try to call Sigma: Technical Support: 1.800.896.6858
12/9/2014 7:44:59 AM • Sigma 70-300mm... • Answered on Dec 09, 2014
Macro function
The difference will be that it should allow you to focus closer then normal. I own a macro lens with a switch like that, normally it focuses to 4.5 ft minimum. But if i'm zoomed up to 100mm, i can flick the switch to allow me to focus up to 3 ft away. If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
6/5/2012 5:32:46 PM • Sigma 70-300mm... • Answered on Jun 05, 2012
Lens doesn't work but the
"F--" means the camera thinks there is either no lens attached or a non-cpu lens is attached. Looked on bottom of camera for a very small reset button. If one is there, turn camera on and press for about 2 seconds. With camera off, remove lens and with a slightly moistened pad, clean electrical contacts on bot lens and camera body. If neither works, see if a different lens does work. If a different lens works, then it is the original lens, if not, it is the camera.
12/22/2010 7:43:51 AM • Sigma 70-300mm... • Answered on Dec 22, 2010
Bought a Sigma DG 70-300mm 1:4-5.6 autofocus for
The Sigma 70-300mm f/4-5.6 DG will not autofocus with the D40 since the lens does not feature an internal focusing motor (HSM). The D40 does not have an AF motor in the body and hence it can autofocus only with lenses featuring an integrated motor (eg. Nikon AF-S lenses, Sigma HSM lenses, Tokina DX II series etc). Unfortunately you can use the said lens only in MF mode.
9/2/2010 6:52:56 AM • Sigma 70-300mm... • Answered on Sep 02, 2010
I have been using a Sigma DG 70x300 lens on my Nikon D-60
This lens has a motor fitted to it to work on a D60 have you moved the A/M switch to M if not the lens is faulty and will need repair
1/1/2010 8:51:19 PM • Sigma 70-300mm... • Answered on Jan 01, 2010
Sigma 70-300 lens will not move in auto mode.
It's almost certainly got a stripped drive gear. This is not a DIY repair, but if the rest of the lens is in excellent condition and not more than around five years old then it's probably cost effective to get it repaired. Sigma are normally excellent at supplying spare parts for their lenses.
Get an estimate for the work from a photographic repair specialist but be prepared for at least a four to six week turnaround time as that's what I'm currently finding for good repair outlets on both sides of the Atlantic.
7/19/2009 10:01:17 PM • Sigma 70-300mm... • Answered on Jul 19, 2009
Where can i download user manual for sigma dg
I would call the company directly for that manual. They may be able to email you one in pdf form. Here is the website for that company.
www.sigmaphoto.com/lenses
Good luck
7/11/2009 7:54:33 PM • Sigma 70-300mm... • Answered on Jul 11, 2009
Sigma 70-200mm f2.8 APO EX while on Autofocus mode the focus ring moves slightly when half-pressing. Is this normal? is there anyway to fix this?
It is not normal for the focus ring to move slightly when using autofocus mode on the Sigma 70-200mm f2.8 APO EX lens. This could be caused by a problem with the lens or with the camera body. One thing you can try is to check if the lens mount on the camera is clean and free from debris, as this can cause the lens to move when the camera's autofocus system is trying to adjust the focus. You should also check if your lens firmware is updated to the latest version and make sure your camera firmware is also up to date.
1/12/2023 12:18:13 AM • Sigma Cameras • Answered on Jan 12, 2023
Hello All, I need instructions on how to dissasemble the Sigma 300-800mm f5.6 APO EX DG HSM lens to clean an inner element. Does anyone have a service manual/exploded views/parts diagram please?
You can't do this yourself. It needs to be carried out by professionals and is a 'clean room' with service techs in full dust proof protective wear. Send it to them. https://www.sigma-global.com/en/support/ ..
10/5/2022 11:27:10 PM • Sigma Cameras • Answered on Oct 05, 2022
What adapter do I need for a Sigma AF 75-300 lens on a Canon Rebel XTi SLR?
Question edited for clarity. You get the Sigma lens for the camera in Canon fit. https://www.google.com/search?q=sigma+lens+af+75-300+for+canon+rebel+xti Can you use Sigma lenses on Canon cameras? Since Sigma lenses are made to be fully compatible with Canon cameras, they are backwards-compatible. This means that you can use a Sigma lens on a Canon DSLR camera. Similarly, the Sigma cameras are backwards-compatible with Canon lenses. Macro adapter loses the AF feature. https://www.google.com/search?q=sigma+lens+af+75-300+mount+adapter+ring+for+canon+rebel+xti
3/20/2022 12:10:41 PM • Sigma Cameras • Answered on Mar 20, 2022
Where can I find out how to take apart a Sigma 150-600mm contemporary lens?
Taking it apart is not the problem - re-assembling it will be. Unless you have access to an optical laboratory, where laser instruments can measure the exact tolerances required, don't even think about it. You will be left with a pile of optical components, and a far higher repair bill than if you had just let the experts sort out the problem in the first place.
12/6/2021 7:57:17 PM • Sigma Cameras • Answered on Dec 06, 2021
Sigma 18mm f/3.5 - How to open front end to clean?
Best you don't open it at all as you can damage the lens. Send back to manufacture
1/23/2019 4:32:39 PM • Sigma Cameras • Answered on Jan 23, 2019
Why does my sigma tiffen lens work on my rebel T5i & not on my rebel T2i camera says no connection to lens
Tiffen is a brand of filters not a lens. if your sigma lens will work on 1 camera and not on the other then check the lens mount, electronic contacts, clean them if needed. check the settings in the camera if there needs to be a change.
2/10/2018 4:56:20 AM • Sigma Cameras • Answered on Feb 10, 2018
I have a 170-500 Sigma zoom lens and I need a scheme to understand how to mount it. It was disassembled by an unqualified technician and now he failed to mount it. Thanks.
Take it to a Qualified technician and get it fixed properly. I have this same lens for my Pentax K3, its a very good lens and worth getting it fixed by a proper tech who knows what they are doing.
2/10/2018 3:40:20 AM • Sigma Cameras • Answered on Feb 10, 2018
Sigma DM38 serial 233894
OK - what about it ?
8/2/2017 3:50:23 PM • Sigma Cameras • Answered on Aug 02, 2017
Where to find a english manual for sigma 1609?
This is a cycle computer not a camera. Try Sigma-Sport
5/13/2017 10:36:23 PM • Sigma Cameras • Answered on May 13, 2017
Sigma 70-300mm f/4-5.6 DG Lens Logo
Popular Tags
11 questions posted
Top Sigma Cameras Experts
Steve
David Shaub
Are you a Sigma Camera Expert? Answer questions, earn points and help others
View Most Popular
Sigma Cameras
  • Sigma Cameras
Most Popular Question
recently obtained sigma dg 70 300mm lens
  • Cameras
