20 Most Recent
Panasonic TH-58PZ700U 58 in. Plasma HDTV Questions & Answers
How to fix TH-58PZ700U 58 in. HDTV Plasma Television blinks 10 times
With Panasonic Plasma TV, 10 blinks swill never occur. It shoud be either 9 or 11. Count it once more. Visit the site named '
Electro-help'
for more details. Click this
link. View it in
Timeslide or
Flipcard
option, which can be selected from the drop down box menu by the
Sidebar tag,
at the
top left corner of the display window. You can also click the
Home tab to see the latest
updates. It will make search
easier. There are more than 1400 posts
to different brand TVs till now. Setup
proceedings and code list to different brand remote controls also
included.
Pull up older posts or do a
search by
type in the Brand Name of your device in the
Search Box,
at the
top right of the display window.
12/14/2012 2:43:28 PM •
Panasonic...
Answered
on Dec 14, 2012
Panasonic TH-58PZ700U, has sound, no
Ur tv still able to see picture photo on ur tv video functions,tv should be still able to work.Tries tv and cable or satalite boxes unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting and those pay boxes to reboot and upgraded it softwares.U have the tv original remote?Yes?Push the tv menu button if ur tv have a video menu than it is a very good new.Tries tv resetting every modes on the tv Menu back to factory setting.Tv should funsctions again.After tries to resetting the tv and rebooting those pay signal boxes,if tv still getting no tv video signal.Than those tv backlight buffer boards for the Plasma screen X or Z are dead could be either X or Z or both.Find the closed it is authorize LCD and Plasma tvs shops for repair.Best because they have the equipments to determine the exact buffer board is or are dead.
8/17/2011 8:05:06 PM •
Panasonic...
Answered
on Aug 17, 2011
Panasonic TH-58PZ700U has intermittent rectangular streak
This one is going to take a little diagnosis. At this point the best way to narrow it down is to find a pattern. Is the area effected around 1/6th of the entire screen? The screen is broken into sections in the X-Y plane. If you can narrow the area down to a fraction of hte entire screen area, it will help to determine the section of the circuitry that is having a problem. Strangely enough, it could be as simple as a poor connection from the panel to the driver circuitry. The signal levels inside are extremely low and it does not take much to create a problem. If hte unit is no longer under warranty, I would first remove the back and carefully reseat all of the cables and connectors. Since this is not completely reproducible, proving that it is "fixed"ay not be so easy.
Again, look for patterns and X-Y plane areas.
Thanks,
Dan
8/26/2009 3:49:52 PM •
Panasonic...
Answered
on Aug 26, 2009
