20 Most Recent Sony Str-k750p Av Reveiver Questions & Answers
Some models of systems will switch to a new source automatically if the source sees a new signal coming on. Try disconnecting the device on your Video 2 to see if this is the case.
I have seen the IC or component(s) in the switching circuits become defective and cause unpredictable or faulty operation. This can also be a fault condition you are seeing.
Sony Str-k750p... | Answered on Apr 02, 2017
if all connected correctly check see if fuses inside or outputs could be blown
Sony Audio... | Answered on Dec 18, 2019
Find out why your Sony is in protect mode and repair it to restore normal operation. This is a common problem with Sony equipment and often is traceable to cold or poorly soldered connections.
Sony Audio... | Answered on Dec 17, 2019
Probably the changer mechanism has failed. You will have to disassemble your Sony unit to salvage the discs. As a test, try playing a single disc. You may be able to use your Sony in a limited way.
Sony Audio... | Answered on Dec 15, 2019
Take it apart an on the rear of the display you will see capacitors. You will probably see an end cap that is domed. Just replace them all.
Sony Audio... | Answered on Dec 10, 2019
Try this and let me know. First unplug the unit. Plug it back in. When you first push the power button, you should hear 1 click followed by another withing 5-20 seconds. My guess is that you don't hear the second click. Am I right?
Sony Audio... | Answered on Nov 30, 2019
You have this backwards. Applicable code(s) will be found in the remote control, if it is compatible.
Sony Audio... | Answered on Nov 28, 2019
Applicable code(s) will be found in a compatible remote control.
Sony Str-k750p Av Reveiver Logo
4 questions posted
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sony str k750p av receiver automatically
  • Audio Players & Recorders
