20 Most Recent RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat Questions & Answers
This may sound silly, but . have you checked your sytem setup settings to make sure it is set to 5.1 ,if so then you may very well have a bad channel
RCA Onkyo... | Answered on Nov 24, 2014
Does the vu meter show anything(bars moving up and down when audio is present?If so you may have a blown fuse or bad IC in the amplifier section causing the problem. If there is no indication of audio on the front panel it would be a Microprocessor problem
Your RCA remote control may or may not contain the necessary codes. If it doesn't, you are likely to need a compatible universal remote control, possibly an RCA.
RCA Audio... | Answered on Jul 04, 2020
YOU CAN NOT ODD AS IT SEEMS
RCA Audio... | Answered on Apr 24, 2020
You did not list the model numbers of either item but I can tell you that the new televisions use HDMI to send and receive audio. With that in mind, there is no way to do what you want to do unless you buy a converter like this one: https://www.amazon.com/AGPtek-SPDIF-Extractor-Converter-output/dp/B00ECTHIKK
RCA Audio... | Answered on Apr 20, 2020
PLUG CHARGER IN AND TRY TURNING IT ON . IT MIGHT NEED A NEW BATTERY
RCA Audio... | Answered on Apr 18, 2020
Slide the switch Lock/Wake/Clock on the top of the unit to clock position. Press REV or FWD to set the clock time. The time decrements or increments will follow by a faster rate when you press and hold the buttons. The ":" between hour and minute time flashes when you are setting the time.
https://voxxintl.zendesk.com/hc/en-us/articles/225310027-Operating-the-RCA-RP5420-Dual-Alarm-Clock-Radio
RCA Audio... | Answered on Apr 16, 2020
I bought a new universal remote because my RCA Home Theater remote went bad,
took a few hours to figure out that I had to use the Audio remote code on the list.
I have RCA RCRN06GR Blu-Ray Home Theater. The audio codes that came
with my new remote are 41609, 41254, 41390, 41511, 42041. I believe it was 41254 but try them all if it doesnt work.
RCA Audio... | Answered on Apr 07, 2020
First the music files need to be converted to mp3 file format before copying to your MP3 player. Please click on this link for instruction on converting music files and copying to your player :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
RCA Audio... | Answered on Apr 03, 2020
PCM mode is a digital audio file that should be sent to the soundbar via an optical or coaxial digital audio cable. The coaxial digital audio cable uses an RCA plug but not the L/R stereo channels of analog audio. The aux input is usually the 3.5 MM cable from a computer, CD or MP3 player or a cell phone or tablet.
First, which type of RCA cable is connected between the sound bar and the TV? Second, are you sure that the TV connection is an audio out? (A number of recent TVs have only one audio output. This means there is only the optical audio out and not even a headphone jack.)
Once you double-check the input at the sound bar, choose the Line In input if you are using the stereo RCA cable. If you are using the Optical input, select that input. Use either the Mode button or the specific input button on the remote. Then double-check that the TV is set for the appropriate audio out.
I hope this helps. Please add a comment with the model of the TV and the sound bar for further information. I looked at the ONB18SB001 documentation for some of this. The manual for this Onn soundbar is available at Manuals Lib. See https://www.manualslib.com/manual/1498038/Onn-Onb18sb001.html?page=12#manual for the list of input modes and the input to which they correspond. Here is the image of the inputs on the back of the ONB18SB001: https://www.manualslib.com/manual/1498038/Onn-Onb18sb001.html?page=7#manual .
RCA Audio... | Answered on Feb 26, 2020
museumofmagneticsoundrecording.org > ManufacturersRCA
Reel to Reel Tape Recorder Manufacturers RCA - Museum of ...
There is no mention of RCA's reel to reel tape recorders in that summary. ... The acquisition of Victor also gave RCA superior manufacturing and distribution ... recorder/ reproducer used at broadcast studios in the late 1960s, 70s and early 80s. en.wikipedia.org > wiki > Reel-to-reel_audio_tape_recording
Reel-to-reel audio tape recording - Wikipedia
Ampex produced pre-recorded reel-to-reel tapes for consumers of popular and classical music from the mid-1950s to the mid-'70s, as did Columbia House from 1960 to 1984. ‎History · ‎Pre-recorded reel tapes · ‎Tape speeds · ‎Digital reel-to-reel clickamericana.com > Topics > Vintage science & classic technology
Getting real with vintage reel-to-reel tape recorders - Click ...
Jun 26, 2018 - Reel-to-reel tape recorders hit the commercial market in the 1940s -- and ... to Amazon or other companies, and purchases made via these links ... Bing Crosby and his early Ampex tape recorders ... Vintage Sony reel-to-reel tape recorders(1970) ... RCA Victor solid state reel-to-reel vintage tape recorders.
RCA Audio... | Answered on Jan 31, 2020
RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat Logo
Popular Tags
2 questions posted
Top RCA Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
help surround speakers not working 5 1
  • Audio Players & Recorders
