20 Most Recent JVC Kd-s37 Car Audio Stereo Cd/mp3/ipod/wma Usb Aux Player Receiver Am Fm Radio Questions & Answers
      • vcwuaaaaasuvork5cyii=
  • Attention JVC consumers!
  • JVC's Consumer Customer Care Center can help you with most product or service related questions you might have. This number is for home-use TV's, VCR's, DVD's, car audio and portable electronics:(800) 252-5722
  • JVC Pro Support Page
    JVC Kd-s37 Car... | Answered on Dec 05, 2014
    Richard, I am sorry to say that JVC no longer carries an operation manual for that particular model. It is very possible that what you have is a unit that had so many problems that JVC stopped production and quit printing/selling manuals for it.
    JVC Kd-s37 Car... | Answered on Oct 18, 2014
    Change your Home Station in the DAB settings. If you do that and it reverts back, there _may_ be a motherboard battery that needs replacing. It is losing its memory when it is turned off.
    https://www.manualslib.com/manual/1366367/Jvc-Ux-D150.html
    JVC Audio... | Answered on Feb 09, 2021
    First, contact Bell and inquire whether their remote control contains the appropriate code.
    JVC Audio... | Answered on Jan 10, 2021
    Contact JVC to request.
    JVC Audio... | Answered on Jan 03, 2021
    Request the manual directly from JVC.
    Order the service manual from JVC.
    JVC Audio... | Answered on Jan 02, 2021
    Find the components that failed and replace them.
    JVC Audio... | Answered on Dec 01, 2020
    1. Open internal fuse
    2. Open power switch
    3. Power supply failure
    JVC Audio... | Answered on Nov 29, 2020
    Clearly there is a short circuit somewhere in the circuit after the fuse.
    A close examination of the circuit and components might reveal evidence of the location of the short but if not it will mean disconnecting things one at a time until the short circuit disappears.
    JVC Audio... | Answered on Nov 28, 2020
    In my experience the JVC brand hasn't maintained it's early promise of quality and I avoid the brand these days.
    It would have been helpful if you described the noise and mentioned whether it was constant on both FM and AM. Excessive noise isn't unusual on AM due to the inability of the basic circuitry to reject the various sources of interference found in the average home, partly because the AM ferrite rod antenna is usually inside the radio. The average AM radio is highly receptive to receiving and amplifying lots of interference from many sources especially that radiated by fluorescent lighting, cfl bulbs and even nearby mains wiring resulting in a loud hum or buzz.
    With the high popularity of FM and the introduction of DAB that has increasing popularity, the development of AM receivers ceased several decades ago.
    FM is immune from that type of interference but is by no means able to reject all interference and a powerful signal from an external antenna produces the best result, the best signal to noise ratio.
    Assuming the radio isn't faulty, the problem is most likely interference. If the power cord has a ground conductor it is very important it is connected to a good electrically quiet ground. If this isn't possible it could improve things to use an independent ground to the outer conductor of the coax cable to the FM antenna.
    JVC Audio... | Answered on Aug 22, 2020
    Pressing the mute button again!
    JVC Audio... | Answered on May 29, 2020
    Type: auto reverse, double compact cassette deck
    Track System: 4-track, 2-channel stereo
    Tape Speed: 4.8 cm/s
    Heads: 1 x record/playback, 1 x playback, 1 x erase
    Motor: 1 x capstan, 1 x reel, 1 x mechanism
    Tape Type: type I, CrO2, Metal
    Noise Reduction: B, C
    Headroom Extension: HX Pro
    Frequency Response: 20Hz to 17kHz (Metal tape)
    Signal to Noise Ratio: 73dB (dolby C)
    Wow and Flutter: 0.08%
    Total Harmonic Distortion: 0.8%
    Input: 80mV (line)
    Output: 300V (line)
    Dimensions: 435 x 133 x 328mm
    Weight: 4.9kg
    JVC Audio... | Answered on May 01, 2020
    JVC Kd-s37 Car Audio Stereo Cd/mp3/ipod/wma Usb Aux Player Receiver Am Fm Radio Logo
    2 questions posted
    Popular Products
    Top JVC Audio Players & Recorders Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Marvin
    Marvin
    Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
    View Most Popular
    • JVC Audio Players & Recorders
    Most Popular Question
    jvc kd s37 car stereo need manual plus
    • Audio Players & Recorders
