20 Most Recent Canon BJ-W9000 Copier Questions & Answers
When making On, the printer
this error code, stand for print head trouble.
You can try following:
1. Visual inspection:
Press down the BJ print head set locking lever to set it in a proper position if the
lever is pulled up.
Install the BJ print head if it is not installed.
2. Carriage unit
Visually check and replace faulty BJ print head set components or BJ print head
locking lever.
3. Replace the head controller.
4. Replace the system controller.
Hope that helps!
5/31/2011 12:51:06 PM • Canon BJ-W9000... • Answered on May 31, 2011
Have been looking for a BJ-W9000 user manual for
I have the bjw 9000 manuel on my desk top
email me at [email protected] and i will send you a copy
Tony
4/29/2011 1:40:41 PM • Canon BJ-W9000... • Answered on Apr 29, 2011
My bjw9000 is pumping ink
It looks like you need to replace printhead and purge unit.
Hope that helps!
4/28/2011 7:45:57 AM • Canon BJ-W9000... • Answered on Apr 28, 2011
How do I reset the
Eat some magic mushrooms and the language suddenly becomes clear, understandable
2/17/2011 10:49:23 PM • Canon BJ-W9000... • Answered on Feb 17, 2011
Hi I don't have a user manual for the Cannon
Print-position sensor calibration warning
Error occurred when calibrating the print-position sensor before the paper-width
detection sequence.
cHECK SENSOR
6/23/2010 1:18:14 PM • Canon BJ-W9000... • Answered on Jun 23, 2010
I'm getting an error code of W8102. Can anybody
W8101/8102 - Print media position warning
The paper over the platen lies too near or too far from the carriage home position
when fed into the printer.
Cause>
The paper on the platen was too close to or too far from the carriage home position
side when paper was fed.
<Probable faulty component>
The way in which paper is set, print paper, cassette/cut-sheet feed unit, carriage
unit, encoder sensor unit, linear scale, carriage controller, head controller, system
controller.
<Action>
1. Paper setting check:
Reset the paper if the setting is not correct.
2. Paper check:
Replace the paper when any stains or pre-prints are found.
Straighten or replace the roll media when the roll of paper is ruffled.
3. Cassette unit/cut-sheet feed unit:
Replace the faulty paper feed component when the paper feeding is performed
correctly in all parts except where the error occurred.
4. Check the linear scale:
Visually check the linear scale for abnormal conditions, such as stains or damage.
5. Replace the carriage unit.
6. Replace the head controller.
7. Replace the system controller.
6/15/2010 8:42:27 AM • Canon BJ-W9000... • Answered on Jun 15, 2010
2answers
Canon BJ-W9000 Error code
Hi Dan,
I have a user manual at home, sorry I am at work at the moment.
I am not sure if it has your code in there but I will have a look, if so I will get back to you.
Sorry this does not fix your problem straight away.
I have a problem that you may be able to help me with?
My fiery controller has crashed!
I need a copy of the disc for the controller, it a Image Pass-W20 print controller, I believe this is the standard print controller sold for this model.
I run PC computers with XP but i think the controller run NT, so i am not sure how they manage to talk to one another?
Any help would be appreciated.
Thanks
Steve
[email protected]
8/29/2009 6:35:56 PM • Canon BJ-W9000... • Answered on Aug 29, 2009
Canon BJ - W9000 Error code: B800A
The BJW 9000 manuel is available as a free download I have downloaded it my self but dont have it at home why not do the same
Tony (withtrader)
best of luck
7/14/2009 8:06:47 PM • Canon BJ-W9000... • Answered on Jul 14, 2009
ERROR MESSAGE FOR CANON BJ-W9000
Hi Caroline here is the problem defonition
E7260
: Nozzle check sensor unit error
E7270 to E727b/W7280/E7281/E7290/ E7291
:Nozzle check error
<Cause>
The position of the nozzle check sensor unit was faulty.
An abnormal condition occurred in the nozzle check sequence.
An abnormal vibration in the printer, the BJ print head is abnormal or no ink was
delivered to the BJ print head.
BJ print head, nozzle check sensor ***'y, linear scale, encoder sensor unit, carriage
controller, head controller, system controller.
<Action>
1. Check the ink filling status:
Execute "Fill Ink" from the Service Mode when there is no ink in the ink tube of
the carriage caterpillar component. Execute cleaning when the carriage air buffer
is filled but the ink tube of the BJ print head locking lever is empty.
2. BJ print head:
Replace the BJ print head if the above procedure does not solve the problem.
3. Nozzle check sensor check:
Re-install the nozzle check sensor holder unit if the installation condition is
incorrect.
If the installation condition is correct, select "Nozzle Check Position" from the
Service Mode, turn the power off and on, and obtain the updated and appropriate
nozzle check position.
4. Replace the nozzle check sensor ***'y.
5. Check the linear scale:
6. Replace the carriage controller.
7. Replace the head controller.
8. Replace the system controller.
9. Replace the carriage unit.
I hope this helps
If not please get back to me
Thank You
6/14/2008 7:51:08 PM • Canon BJ-W9000... • Answered on Jun 14, 2008
Installed new ink tank not detecting ink
Go to this site and look at " save my inkjet"
http://checkitright.spruz.net//main.asp?page=dp&dis=592197
then go to "keep your head clean"
2/15/2008 3:13:53 PM • Canon BJ-W9000... • Answered on Feb 15, 2008
My copier canon imageRunner c5250i given message that remove paper from output tray but there is no paper. I need your help please
There's a plastic flag that goes through an optical gate and tells the printer that the output tray is full. The flag is stuck, broken or missing, or the optical sensor is dirty. Search for the flag at the level where the paper would be if the tray is full.
3/16/2023 5:40:52 AM • Canon Office... • Answered on Mar 16, 2023
Wan i copy / print in canon 3320 printer sum sound than shoeing on display code YE000025-0410 this code i want to no wire is the problam
  • The error code "YE000025-0410" on a Canon 3320 printer typically indicates a problem with the paper feeding mechanism. This can be caused by a variety of issues, such as a paper jam, a misaligned paper tray, or a problem with the paper sensor.
To determine the exact cause of the issue, you may need to perform some troubleshooting steps. Here are a few things you can try:
  1. Check for paper jams: Open the printer cover and check for any stuck or crumpled paper inside. Remove any paper that you find and close the cover.
  2. Check the paper tray: Make sure the paper tray is properly aligned and that the paper guides are snug against the paper.
  3. Clean the paper path: Use a lint-free cloth to clean the paper path of any dust or debris that may be causing the issue.
  4. Reset the printer: Turn the printer off, unplug it from the power source, wait a few minutes, and then plug it back in and turn it on.
If these steps do not resolve the issue, there may be a problem with the printer's paper sensor or other internal components. In that case, you may need to contact Canon customer support or a certified repair technician for further assistance.
3/15/2023 4:20:39 AM • Canon Office... • Answered on Mar 15, 2023
Problem to put the cartridge tray to printer Canon LBP 5050
  • Canon LBP5050 printer does not have a cartridge tray. Instead, it uses individual toner cartridges for each color (cyan, magenta, yellow, and black) that are inserted into specific slots inside the printer.
To replace a toner cartridge in the Canon LBP5050, follow these steps:
  1. Make sure the printer is turned on and the front cover is open.
  2. Locate the toner cartridge that needs to be replaced. Each cartridge is labeled with the corresponding color.
  3. Hold the handle of the cartridge and gently pull it out of the printer.
  4. Remove the new toner cartridge from its packaging and shake it gently to distribute the toner.
  5. Remove the protective cover from the cartridge.
  6. Hold the handle of the new cartridge and insert it into the corresponding slot in the printer.
  7. Push the cartridge all the way in until it clicks into place.
  8. Repeat this process for any additional cartridges that need to be replaced.
Once all of the toner cartridges have been replaced, close the front cover of the printer. The printer should automatically recognize the new cartridges and begin the toner replacement process.
3/14/2023 1:45:10 PM • Canon Office... • Answered on Mar 14, 2023
I have error E000880-0003 in Canon C52351i ?
The error code E000880-0003 in Canon C5235i usually indicates an issue with the communication between the main controller and the sub CPU. To resolve this error, you can try the following steps: 1. Turn off the printer and unplug it from the power source. 2. Wait for a few minutes and plug it back in. 3. Turn on the printer and see if the error has been resolved. If not, proceed to the next step. 4. If the error persists, try resetting the printer by entering service mode. Press the "Additional Functions" key, then the numbers "2" and "8" at the same time, and then "Additional Functions" again. This should bring up the service mode screen. 5. Select "COPIER" from the menu, then "FUNCTION," then "CLEAR," then "ERR." This will clear the error code. 6. Turn off the printer and unplug it from the power source for a few minutes. 7. Plug it back in and turn it on to see if the error has been resolved. If these steps do not resolve the error, it may indicate a more serious hardware issue and you may need to contact a service technician for further assistance.
3/10/2023 8:54:02 PM • Canon Office... • Answered on Mar 10, 2023
2answers
User manual for Canon printer F156602
I'm sorry, but I could not find any information on a Canon printer model number F156602. Can you please double-check the model number and provide any additional information about the printer? This will help me assist you better in finding a user manual and troubleshooting the issue with your printer.
3/10/2023 12:17:04 AM • Canon Office... • Answered on Mar 10, 2023
Canon ir 2520 print problem
try running a Windows Update as you may need to catch up with who knows how many updates from Microsoft just type into search box bottom left corner of Windows desktop screen Windows Update also is the driver the correct 64 bit version for the IR 2520 rather than a 32 bit version.
3/9/2023 8:05:03 PM • Canon Office... • Answered on Mar 09, 2023
I have a canon 2425 machine, it is giving error e-000602-0020
Error E-000602-0020 on a Canon 2425 machine can indicate a problem with the machine's hard drive. It is possible that the hard drive has become damaged or corrupted, which is causing the machine to be unable to start up properly. There are a few different steps you can try to troubleshoot this issue:
  1. Restart the machine: Try turning the machine off and then back on again to see if the error message clears.
  2. Check the hard drive: Make sure the hard drive is properly installed and functioning. If the hard drive is damaged or not functioning properly, it can cause the machine to display an error message and not start up properly.
  3. Check for any other visible issues: Inspect the machine and its components for any visible issues that may be causing the problem. This can include debris or foreign objects that may have gotten stuck in the machine, or damage to the machine or its components.
If you have tried these troubleshooting steps and the problem persists, it may be necessary to have the machine serviced by a professional. A technician will be able to diagnose the problem and determine the necessary repairs. I hope this information is helpful. If you have any further questions or need additional assistance, please don't hesitate to ask.
3/7/2023 7:03:19 PM • Canon Office... • Answered on Mar 07, 2023
2answers
I have canon IR 2425 has error code E000733-0000 so what shall I do to solve it?
Error code E000733-0000 on Canon IR 2425 indicates that there is an issue with the toner waste container. Here are the steps you can take to resolve the error:
  2. Open the front cover of the printer and remove the toner waste container.
  3. Check the waste container for any blockages or obstructions. If you find any, clean them and reinsert the waste container.
  4. Check if the waste container is full. If it is full, replace it with a new one.
  5. Close the front cover of the printer and plug it back into the power source.
  6. Turn on the printer and check if the error has been resolved.
If the error persists, you may need to contact a certified technician for further assistance as it could indicate a more serious hardware issue.
3/3/2023 5:04:43 AM • Canon Office... • Answered on Mar 03, 2023
2answers
Haw can i reset bios mode update firmware for ir 2420 canon copier
1) Restart your system by clicking Start, clicking the power icon, and, then pressing Restart. Wait until the start screen of the computer appears. 2) Tap the delete or F2 repeatedly to enter the setup. Wait until the bios loads. The Setup Default option should be displayed. Choose the 'Load Setup Default' option and then click Enter. 3) Save your changes and ensure that the changes are as per your choices.
3/1/2023 7:29:18 PM • Canon Office... • Answered on Mar 01, 2023
Canon BJ-W9000 Copier Logo
Popular Tags
15 questions posted
Clive
Clive
old marine
old marine
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
bjw9000 pumping ink
  • Office Equipment & Supplies
