20 Most Recent M-Audio Audiophile USB Audio and MIDI Interface (Macintosh and and Windows) External Sound System Questions & Answers
I couldn't find any manual this big.
This is their manual: http://www.m-audio.com/images/global/manuals/Audiophile-USB_Manual.pdf
Hope this helps. If you need anything else, please leave a comment.
M-Audio... | Answered on Feb 13, 2011
Is it bus powered? If it is only plugged into the USB port and not also into the AC outlet, it may be because your USB port does not supply enough voltage or enough current. USB is spec'd at 5V, 500mA, but many fall short. I have the same problem with a Tascam US-122. I haven't tested yet, because it doesnt have an external power port. I would need to splice 5V power into the USB cable.
M-Audio... | Answered on Jun 10, 2010
the latency is in the sound card.
usually you can set the CPU cache to 512 in a program or synthesizer.
Your Korg softwear may be able to ajust this if it is on your pc. Most PC have the sound card built into the mother board thereby not cutting the performance.
2. You will have to purchase a external sound card for your Audio and midi interface to get the least amount of latency.
The PC cabinet with all it components has a lot of EMI (Electromagnetic interference) that cause some of the latency issues with these device. If you can live with 2ms latency which the human ear can't determine then you can render a acceptable audio and midi setup, The Ableton Live 8 series has a latency setting for the CPU in the program. Download the demo and see if you notice a difference.
M-Audio... | Answered on Apr 16, 2010
prehaps the usb sound card isnt compatible with mac
M-Audio... | Answered on Jan 10, 2009
Sir,
I am using lenovo system IBM & this system format, but sound card not match this system.  You are requested to please solve the problem.
M-Audio... | Answered on Dec 24, 2008
Ok her's wuz up! It's the install **** that this driver's been tackling with since the beginning! (This somewhat goes for the oSX to i gues =) Anyway, so...
1. Uninstall the whole thing! Also run regedit (XP,Vista?) and delete everything named "Audiophile" (installed audio apps mostly recognices to the new drivers once installed so don't worry).
2. Then reboot and run the new drivers - and remember that old ****, click "continue anyway" at all THREE times.
3. Then reboot again (do NOT turn the card on yet). I turned it on after shortly after BIOS screen and that was almost too early! Anyway, then follow the "found new harware" routine - TWO times - one for SOUND and one for MIDI.
This might seem basic and all but, hey... with theese kind of cards.. sheeesh!. And when ARE they going to get there "protocal" aproved?! Next OS?!
M-Audio... | Answered on Nov 15, 2008
i have no sound drive in my system so please permit me 2 download sound drive from ur product please grant me 2 download
M-Audio... | Answered on May 18, 2008
Sounds like a USB issue. Is the device self powered? Did you try plugging in a different USB cable? Is it plugged into a powered hub?
USB 1.1 devices and USB 2 devices can cause issues together on the same bus or port. Try keeping devices separate or plug in just the maudio device. I had issues with USB Network adapters not being seen all the way because there was a older usb 1.1 device on the same hub.
M-Audio... | Answered on Apr 18, 2008
use it at 16Bit instead of 24bit, and also use it as ur ONLY sound card i just got rid of that problem myself, looking for the midi help now..
M-Audio... | Answered on Feb 22, 2008
i have the mid-air 25 keyboard i think the interface and compatibility with windows xp is awesome! easy to use easy to program settings into and tons and tons of neat features built into the keyboard itself....hrmm upon looking it seems the series has been discontinued for some reason... under that knowledge i would suggest one of possibly these systems for price and quality
http://www.m-audio.com/products/en_us/KeyRig25-main.html
http://www.m-audio.com/products/en_us/KeyRig49-main.html
about 129 each and each have great features and well as fuctionality and windows compatibility.
hope this helps
M-Audio... | Answered on Feb 15, 2008
Here it is http://video2ringtone.com/
M-Audio... | Answered on Aug 01, 2019
Measure it myself from original card and cable.
M-Audio Audiophile 192 Pinout
DB25 Male, front view:
01 02 03 04 05 06 07 08 09 10 11 12 13
14 15 16 17 18 19 20 21 22 23 24 25
In and Monitor cables are connected to same pins (so are interchangable):
22 In L Gnd - Monitor L Gnd: iLg
21 In L Tip - Monitor L Tip: iL+
09 In L Med - Monitor L Med: iL-
08 In R Gnd - Monitor R Gnd: iRg
07 In R Tip - Monitor R Tip: iR+
20 In R Med - Monitor R Med: iR-
Main OUT:
19 Out L Gnd: oLg
18 Out L Tip: oL+
06 Out L Med: oL-
05 Out R Gnd: oRg
04 Out R Tip: oR+
17 Out R Med: oR-
Midi (Female connectors):
11 Midi Out 4 mO+
12 Midi Out 2 mOg
24 Midi Out 5 mO-
13 Midi In 4 mI+
25 Midi In 5 mI-
Midi In specifications leave Gnd pin 2 unconnected.
So connector its:
01 02 03 oR+ oRg oL- iR+ iRg iL- 10 mO+ mOg mI+
14 15 16 oR- oL+ oLg iR- iL+ iLg 23 mO- mI-
M-Audio... | Answered on May 06, 2019
M-Audio Audiophile USB Audio and MIDI Interface (Macintosh and and Windows) External Sound System Logo
18 questions posted
Top M-Audio Computers & Internet Experts
Edward Easley
Edward Easley
Gustavo Ortiz
Gustavo Ortiz
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • M-Audio Computers & Internet
Most Popular Question
midi interface suitable me
  • Computers & Internet
