20 Most Recent
Targus 4-PORT TRAVEL USB 2.0 HUB W/NOTEBOOK LIGHT (Retail) Questions & Answers
Targus Travel USB 2.0 4-Port Hub with Notebook Light
I'm sorry to tell you your hub cannot be fixed. I have one just like it and have taken these things apart and repaired simple factory errors as loose wires and the such.
You should get yourself another Targus brand USB hub. They are good and quite reliable
Regards,
Worldvet.
How to open a Targus Chill Mat Pad AWE61US N2953
Without specific details about the type or model of the mat you're referring to, it's challenging to provide precise disassembly instructions. However, I can offer some general tips that might help you access the inside of the mat for cleaning without causing damage:
- Consult the Manual: If the mat came with a user manual or assembly instructions, refer to these documents first. They often contain disassembly guidelines or tips for cleaning.
- Look for Access Panels or Fasteners: Many mats or fitness equipment have access panels secured by screws, clips, or fasteners. Carefully inspect the mat's exterior for any visible fasteners or panels that might provide access to the inside components.
- Check for Removable Parts: Some mats might have removable parts like covers or casings designed for cleaning purposes. Gently try to detach these removable components, following any instructions in the manual or indications on the mat.
- Contact Manufacturer Support: If you're unable to find a way to disassemble the mat safely or if you're concerned about causing damage, consider reaching out to the manufacturer's customer support. They can provide specific guidance on disassembly and cleaning for your particular mat model.
- Online Resources: Look for online resources such as instructional videos or forums where individuals might have shared tips or experiences on disassembling and cleaning similar mats.
Always approach disassembly cautiously to avoid causing damage or voiding any warranties. If you're unsure or uncomfortable about disassembling the mat yourself, seeking professional assistance from a technician or contacting the manufacturer for guidance might be the best course of action.
