20 Most Recent M-Audio Delta 1010 PCI CARD Sound Editing & Recording Sound Card Questions & Answers
on output of sound cardsare coloured sockets,headphone/speaker socket is green
M-Audio Delta... | Answered on Jan 19, 2015
It has 8 mono inputs or 4 stereo pairs, which can be recorded in cubase or whatever sequencer at once.
M-Audio Delta... | Answered on Jun 13, 2012
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question mark? right click to re-install drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
cnetdowload.com if these drivers are not suitable on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html
http://www.freeware-downloads.com/soundmax_integrated_digital_audio_driver_v.htm
SoundMax Integrated Digital Audio Driver v hope this helps
M-Audio Delta... | Answered on May 22, 2011
TRY RE INSTALLING IT
M-Audio Delta... | Answered on Nov 25, 2010
Drivers for that sound card can be downloaded from M-Audio's support site linked below.
http://www.m-audio.com/index.php?do=support&tab=driver
Choose Delta Series Card>Delta 1010>Select OS and you should be able to download the drivers.
Robert from Blitware
M-Audio Delta... | Answered on Jun 17, 2010
Your idea is absolutely the correct direction. There must be a smooth interface between the two. I strongly suggest you first remove the 64 bit driver. Remove the sound card and see if the 32 bit driver shows back up. If the 32 bit driver shows back up - remove it. Then remove the card. With the card removed - take a pencil eraser and scrub the cards pins ] the copper looking things going into the pci slot. Look for any blockage in the PCI card slot. Also use AIR and push the AIR right into the Power Supply cage & push out as much dust - [ it's in there] as you can.
Now restart the pc without the sound card and do a quick search for the name of the sound driver. If you have the install disk and there are no little hangers on files - Put the disk in or run the file for 64 bit drivers. NOTE - just because the drivers work doesn't mean the software will work. Check to see the software it self will work. Be sure to know if the instructions ask you to install the card FIRST or NOT - -if first - shut the machine down and install the card. Once the 1010 is back in - boot everything up and check the driver is working. If it isn't working -or partially working - right click the program - properties and choose RUN AS XP.
This will cause your unit to work. If this doesn't work for you. Remove the card and install it in a borrowed or back up machine. If one card is working and one card just like it isn't - AND both are in the same machine swap their positions. Check to be 100% sure you have enough resources to run BOTH cards on that set up. To up tick the RAM is also a good thing. Put in the MAX ram for the machine as Win7 takes a ton of ram -more than any other pc operating system you have ever had. HERE ARE THE BEST DRIVERS
Best of it
Gary
M-Audio Delta... | Answered on May 18, 2010
You can get it here
M-Audio Delta... | Answered on Feb 01, 2009
http://www.gigabyte.com.tw/FileList/NewTech/2006_motherboard_newtech/hd_audio_driver_usermanualver1-00_0418-05.pdf.
Thanx
M-Audio Delta... | Answered on Jan 21, 2009
JE VOUDRAIT INSTALLER DRIVER CARTE SON ET AUDIO POUR MON MICRO ORDINNATEUR
PORTABLE AMILO PRO V 8210
M-Audio Delta... | Answered on Oct 05, 2008
hi
u can try this , please update the driver update for the same issue and update the driver for the sound device or please unistall and reinstalle the sound drivers on the system, or do systemrestore if it was working some days back .... check the
  1. Click Start , Run , and enter services.msc into the Open field. A services window opens.
  2. Scroll down the list of services and find Windows Audio.
  3. Right-click Windows Audio and select Properties .
  4. Select Automatic from the Startup type dropdown list, and click Start to start the audio service.
  5. Click OK and test for sound.
M-Audio Delta... | Answered on May 24, 2008
Here it is http://video2ringtone.com/
M-Audio... | Answered on Aug 01, 2019
Measure it myself from original card and cable.
M-Audio Audiophile 192 Pinout
DB25 Male, front view:
01 02 03 04 05 06 07 08 09 10 11 12 13
14 15 16 17 18 19 20 21 22 23 24 25
In and Monitor cables are connected to same pins (so are interchangable):
22 In L Gnd - Monitor L Gnd: iLg
21 In L Tip - Monitor L Tip: iL+
09 In L Med - Monitor L Med: iL-
08 In R Gnd - Monitor R Gnd: iRg
07 In R Tip - Monitor R Tip: iR+
20 In R Med - Monitor R Med: iR-
Main OUT:
19 Out L Gnd: oLg
18 Out L Tip: oL+
06 Out L Med: oL-
05 Out R Gnd: oRg
04 Out R Tip: oR+
17 Out R Med: oR-
Midi (Female connectors):
11 Midi Out 4 mO+
12 Midi Out 2 mOg
24 Midi Out 5 mO-
13 Midi In 4 mI+
25 Midi In 5 mI-
Midi In specifications leave Gnd pin 2 unconnected.
So connector its:
01 02 03 oR+ oRg oL- iR+ iRg iL- 10 mO+ mOg mI+
14 15 16 oR- oL+ oLg iR- iL+ iLg 23 mO- mI-
M-Audio... | Answered on May 06, 2019
M-Audio Delta 1010 PCI CARD Sound Editing & Recording Sound Card Logo
17 questions posted
Top M-Audio Computers & Internet Experts
Edward Easley
Edward Easley
Gustavo Ortiz
Gustavo Ortiz
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • M-Audio Computers & Internet
Most Popular Question
sound drives free download now
  • Computers & Internet
