20 Most Recent M-Audio Delta 66 Sound Card Questions & Answers
Was your machine working fine? If so, WHY did you do an update? Updates are never a guarantee and fraught with many issues - U only update when there is a valid reason and it is absolutely necessary - then you cross your fingers and risk it!
U have learned the hard way and now all you can do is attempt to undue what you did. U can try a system repair of your OS since the system restore did not do the trick. And if the repair does not work, and you do not have a backup of your drive, you will have to wipe the drive and reload everything. Have fun and good luck!
M-Audio Delta 66... | Answered on Jul 17, 2017
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
M-Audio Delta 66... | Answered on Feb 28, 2011
this like problem is from your sound card driver, try reinstall sound card driver that compatible with your win 7, i think this will work
M-Audio Delta 66... | Answered on Jan 22, 2011
Linux support for Delta 66 does exist with a paid commercial license, however you might try the free download from
that supports OSS (open sound systems).
Make sure you choose the Linux 2.6 (x86) DEB file... that's a Debian package type that Ubuntu bases its builds upon.
Download this to your desktop with the web browser then double-click on it to install it to your system. Additional instructions form the opensound.com download page may provide additional information that you need to know, for example, the driver name may appear as envy24 when you configure OSS to work with your system.
If you're running a 64-bit edition of Ubuntu, then this won't work.
M-Audio Delta 66... | Answered on Nov 21, 2010
Go to Device Manager and enable the audio card.
If you cannot enable the audio card or it is not working then install the audio driver again.
M-Audio Delta 66... | Answered on Mar 31, 2010
high defination audio apparaat is not working bij windows 7
start niet fout 10
M-Audio Delta 66... | Answered on Dec 26, 2009
I'd say to look at latency settings and sample rates. also disable screen savers and power management.
M-Audio Delta 66... | Answered on Aug 26, 2007
Here it is http://video2ringtone.com/
M-Audio... | Answered on Aug 01, 2019
Measure it myself from original card and cable.
M-Audio Audiophile 192 Pinout
DB25 Male, front view:
01 02 03 04 05 06 07 08 09 10 11 12 13
14 15 16 17 18 19 20 21 22 23 24 25
In and Monitor cables are connected to same pins (so are interchangable):
22 In L Gnd - Monitor L Gnd: iLg
21 In L Tip - Monitor L Tip: iL+
09 In L Med - Monitor L Med: iL-
08 In R Gnd - Monitor R Gnd: iRg
07 In R Tip - Monitor R Tip: iR+
20 In R Med - Monitor R Med: iR-
Main OUT:
19 Out L Gnd: oLg
18 Out L Tip: oL+
06 Out L Med: oL-
05 Out R Gnd: oRg
04 Out R Tip: oR+
17 Out R Med: oR-
Midi (Female connectors):
11 Midi Out 4 mO+
12 Midi Out 2 mOg
24 Midi Out 5 mO-
13 Midi In 4 mI+
25 Midi In 5 mI-
Midi In specifications leave Gnd pin 2 unconnected.
So connector its:
01 02 03 oR+ oRg oL- iR+ iRg iL- 10 mO+ mOg mI+
14 15 16 oR- oL+ oLg iR- iL+ iLg 23 mO- mI-
M-Audio... | Answered on May 06, 2019
Have a read at this article. I assume you are using ASIO4ALL if not then you should.
http://www.image-line.com/support/FLHelp/html/recording_audio_USBmic.htm
Specifically this part:
Note about latency: USB microphones generally only allow you to hear the sound being recorded after it has passed through FL Studio. As the latency of USB microphones depends on the ASIO4ALL latency settings, there may be a troublesome delay between the sound made and it being reproduced from your speakers or headphones. For example, low latency monitoring is particularly important to vocalists as high latencies cause a distracting echo effect. The only solution to this problem is to lower your buffer length settings (there are limits) or obtain a new soundcard with direct-monitoring.
M-Audio... | Answered on Feb 24, 2015
Be careful and take off the side panel to the PC tower to expose the inner parts of the computer and there you find that your sound card is inside attached to the motherboard (The Mainboard) get a star or flat head screwdriver and unscrew the screw, slowly put out your sound card (Don't forget to unplug your audio wires first) then what I do is get a Q-tip and dab it in some alcohol then just roll it on the paint leg or napkin and wipe off the little gold tips were the card slides in from BOTH SIDES and also check to see if there is a lot of dust inside your PC its pretty good that you blow it out that way it doesn't overheat as well now just put the card back in and see if that works and if not then you most likely need a driver for it and for that go to the website of the soundcard and go to support and drivers for your sound card version...Hope this helped thanks
M-Audio... | Answered on Jan 01, 2015
Well thevskipping part is the quality of your player, and the sound is often when somebody doesn't know how to convert stuff.
M-Audio... | Answered on Sep 16, 2014
Balance is adjusted with the mixer on your computer. So is the volume.
M-Audio... | Answered on May 07, 2014
M-Audio Delta 66 Sound Card Logo
Popular Tags
10 questions posted
Top M-Audio Computers & Internet Experts
Edward Easley
Edward Easley
Gustavo Ortiz
Gustavo Ortiz
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • M-Audio Computers & Internet
Most Popular Question
windows xp sp3 platform single delta 66
  • Computers & Internet
