20 Most Recent M-Audio Delta 1010 Sound Card Questions & Answers
Check to see if you have your onboard sound turned on. If you do turn it off and this should stop the double voice.
M-Audio Delta... | Answered on Dec 21, 2015
Look in the computer music mags and look fro M-Audio dealers. Ring them up and tell them the problem your having and see how much it will cost to fix. If it's humming then it's proably broke and needs repairing. Just make sure the sampel rate isn't set too low as well
M-Audio Delta... | Answered on Sep 23, 2014
you might have to remove the sound card and make sure the socket is free of dust restart your computer then reinstall it
windows 7 should automatically find the drivers and install them
click start right click on computer select properties in the left hand panel device manager scroll to
sound and video game controllers if you see a yellow qustion/exclamation mark ? ! or a red X
a newe driver will need to be reinstalled
hope this will help
M-Audio Delta... | Answered on Sep 25, 2011
You can download the Delta 1010 drivers from the website http://www.m-audio.com/index.php?do=support.drivers&f=736
I hope this works for you :)
Regards,
Aby
M-Audio Delta... | Answered on Apr 21, 2010
This site is useless. I posted this problem awhile back and nothing is posted for it. Don't waste your time here.
M-Audio Delta... | Answered on Dec 05, 2009
WORKING DRIVER HERE FOR M-audio PCI:
 M-Audio Delta 44 (verified)
 M-Audio Delta 66 (verified)
 M-Audio Delta 410 (verified)
 M-Audio Delta 2496 (verified)
 M-Audio Delta 1010 (works for some)
 M-Audio Delta 1010LT (verified)
 Terratec Phase 88 / EWS88MT / TS88PCI (tested only on EWS88MT)
 Terratec EWX2496
I tested on my M-audio Delta 1010 with box today and everything incl. SPDIF is working great on my osx86 v_7 10.5.8 system! The only thing not working is midi as told on website. Im submitting file for the above sound cards! Dont Forget to donate some money to this guy!!!
http://www.audio-evolution.com/drivers/
http://www.insanelymac.com/forum/lofiversi...t25145-150.html
M-Audio Delta... | Answered on Sep 14, 2009
frequency response: 20Hz-22kHz, +/-0.3dB spacer.gif dynamic range (A-weighted): 109dB (A/D), 117dB (D/A) spacer.gif signal-to-noise ratio (A-weighted): -109 dB (A/D), -117dB (D/A)
I found these on the site, seems you have the khz way too high.
All good.
Here's the link to your site.
M-Audio Delta... | Answered on Jul 23, 2009
try to change the clock sync in the sound card to independent
M-Audio Delta... | Answered on Jan 07, 2009
Hey hoof
My only experience with faint sounds is when ground wires in the particular circuitry are not property connected. That means tracking the wires from the one end to the other if you can get to them. If they are not embended in a casing or housing I would change them.
Also, try changing the RCA plugs; even their connection can cause the sound shorting if there is a short.
Well....hoof... well,,,,good luck buddy.
M-Audio Delta... | Answered on Mar 01, 2008
Here it is http://video2ringtone.com/
M-Audio... | Answered on Aug 01, 2019
Measure it myself from original card and cable.
M-Audio Audiophile 192 Pinout
DB25 Male, front view:
01 02 03 04 05 06 07 08 09 10 11 12 13
14 15 16 17 18 19 20 21 22 23 24 25
In and Monitor cables are connected to same pins (so are interchangable):
22 In L Gnd - Monitor L Gnd: iLg
21 In L Tip - Monitor L Tip: iL+
09 In L Med - Monitor L Med: iL-
08 In R Gnd - Monitor R Gnd: iRg
07 In R Tip - Monitor R Tip: iR+
20 In R Med - Monitor R Med: iR-
Main OUT:
19 Out L Gnd: oLg
18 Out L Tip: oL+
06 Out L Med: oL-
05 Out R Gnd: oRg
04 Out R Tip: oR+
17 Out R Med: oR-
Midi (Female connectors):
11 Midi Out 4 mO+
12 Midi Out 2 mOg
24 Midi Out 5 mO-
13 Midi In 4 mI+
25 Midi In 5 mI-
Midi In specifications leave Gnd pin 2 unconnected.
So connector its:
01 02 03 oR+ oRg oL- iR+ iRg iL- 10 mO+ mOg mI+
14 15 16 oR- oL+ oLg iR- iL+ iLg 23 mO- mI-
M-Audio... | Answered on May 06, 2019
M-Audio Delta 1010 Sound Card Logo
Popular Tags
20 questions posted
Top M-Audio Computers & Internet Experts
Edward Easley
Edward Easley
Gustavo Ortiz
Gustavo Ortiz
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • M-Audio Computers & Internet
Most Popular Question
delta1010 hacintosh
  • Computers & Internet
