20 Most Recent KitchenAid KGRS807SSS Gas Kitchen Range Questions & Answers
Sounds like your range's computer control is bad. It will be a repair man's job to replace it unless he can find a reset problem. Sorry it is not a repair you can do yourself.
KitchenAid... | Answered on Mar 21, 2019
kitchenaid gas oven code F6 E4
KitchenAid... | Answered on Apr 06, 2014
yes this will work for you, but before you change out the fan motor make certain the fan blades are unobstructed and not rubbing against anything this can make quite a horrible noise as well.
best regards Falco
KitchenAid... | Answered on Nov 05, 2013
Unplug the stove for at least two minutes or throw the breaker for the same time. So far, has worked 100% of the time for me for all error codes. Apparently something gets out of whack and turning off or unplugging must reset the system.
KitchenAid... | Answered on Feb 26, 2013
You will need to replace the temp. sensor. Here is the part to order.
KitchenAid... | Answered on Nov 23, 2012
Hello
Burners will not light if there is the smallest amount of water in the holes. Have you washed the stove top recently?clean your stove, turn gas on high, light it with a lighter, and wait about an hour.....its normaly just a bit wet in there doing this lets it dry out.
blow air from your mouth at it as you are clicking it to light or use a match or try cleaning the electronic ignighter off.sometimes they get dirty and wont work
you can usually take the burner out and give it a good clean, make sure none of the holes are blocked with food etc, if its the ignition switch try using a lighter or matches to turn it on,
If these do not work then i suggest you replace the burner but this might be a bt expensive
KitchenAid... | Answered on Oct 18, 2011
Check your circuit breakers and or ground fault circuit interrupters.GFI.
You have no power to the range.
KitchenAid... | Answered on Aug 10, 2011
I am sorry to hear regarding the trouble.
Be advised that as i am not there, i cannot provide legitimate 2nd opinion.However,i would be glad to add few inputs to the diagnosis.
This error message indicates - Oven temperature is too high (Clean mode)
Solution - Replace oven temperature sensor
It is located in the upper corner inside the oven.You need to test it for resistance it should have a reading of about 1100 ohms. If the resistance is wrong, you need to replace it.
Do not forget to ' ACCEPT ' the solution, so that i could get the credit for my time.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
KitchenAid... | Answered on Jul 14, 2011
Hello and sorry to hear about your problem.
It sounds like your oven glow rod, is defective. This is the electronic pilot lite for the unit.
I suggest you can in a service person. If you live in the Denver Co area, I can help you.
I have tried to help you. Please help me by Vote/Rate this response. Thanks and good luck.
cvbb
cvbcb
KitchenAid... | Answered on Mar 27, 2011
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
KitchenAid... | Answered on Mar 06, 2011
KitchenAid KGRS807SSS Gas Kitchen Range Logo
55 questions posted
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
wp4eld1
Level 1 Expert
gbob59
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Kitchen Ranges
Most Popular Question
kitchenaid commercial range kdrp707rss01
  • Kitchen Ranges
