20 Most Recent Daewoo FR-147RV Questions & Answers
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Daewoo FR-147RV • Answered on Sep 24, 2011
TRY CHANGING THERMOSTAT... HOPE IT WORKS ITS RIGHT HAND SIDE OF FRIDGE BY LIGHT.
Daewoo FR-147RV • Answered on Feb 25, 2011
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Daewoo FR-147RV • Answered on Sep 30, 2010
I am in search of Daewoo Refrigerator Service Centre telephone and address in Mumbai, preferably in Dadar. If you know, please mail at [email protected] or Ph. 22653791
From,
Mrs. Padma D. Mulay.
Daewoo FR-147RV • Answered on Jun 02, 2010
Hi, Call Nahim, Mumbai 66945285/6
Daewoo FR-147RV • Answered on Feb 09, 2010
Good news! Straight from the Daewoo website, here is the user's manual link for your Model FRS-2421IAL that you are looking for in an easily clickable and printable form. Just click the link below, look for your model number, and choose "manual".
Hope this helps!
- CBR2009
Refrigerator=>Side%20by%20Side&cpage=6">http://www.dwe.co.kr/english/support/download.asp?class1=4&class2=17&class3=32&selorderby=1&searchpath=Refrigerator=>Refrigerator=>Side%20by%20Side&cpage=6
Daewoo FR-147RV • Answered on Aug 18, 2009
make and model # was there frost on the evap.?
Daewoo FR-147RV • Answered on Dec 05, 2008
Daewoo FR-147RV Logo
Popular Tags
29 questions posted
Top Daewoo Refrigerators Experts
Lawrence Oravetz
NOEL
NOEL
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Daewoo Refrigerators
Most Popular Question
daewoo service centre in new delhi
  • Refrigerators
