20 Most Recent Minolta 280PX TTL Flash Questions & Answers
0answers
How to fix minolta weathermatic a power problem
Are the batteries the right way up ? Is there corrosion within the battery chamber ?
8/26/2021 5:43:21 PM • Minolta Cameras • Answered on Aug 26, 2021
Minolta 500si autofocus stopped working. Tried turning manual focus on and off, restarting, resetting, putting new battery in. Not sure why it isn't sensing the autofocus lens attached. Any ideas?
Try gently cleaning the electronic contacts on the camera body and the rear of the lens, without touching the rear lens element or the mirror in the camera.
1/12/2020 12:00:48 PM • Minolta Cameras • Answered on Jan 12, 2020
What is my Minolta weathermatic 10 x 42 worth?
To whom ? Yourself or a prospective purchaser ? Anyway, Fixya does not provide valuations of equipment, even when posted in the correct forum.
7/29/2019 10:46:55 PM • Minolta Cameras • Answered on Jul 29, 2019
Finding the software to download pictures from my minolta dimage Z3 camera to the computer
Check your 'C' drive on PC. The path to the software will either be C:\Program Files\ or C:\Program Files (x86) if you have installed it. If you need to find appropriate software, contact Konica Minolta, its usually a free download for you to install.
5/19/2019 9:11:04 AM • Minolta Cameras • Answered on May 19, 2019
I am in the UK and need to know if my Minolta Dimage F200 will take a larger than 2GB SD card.
  • Memory Card Form FactorSD Memory Card
  • Included Memory Card Capacity 16 MB
  • Memory Card Slot SD card
  • Supported Memory Cards MultiMediaCard, SD Memory Card
Supported memory cards do not appear to be more than SD. To get above 2GB the supported memory card type should include SDHC.
5/19/2019 9:06:54 AM • Minolta Cameras • Answered on May 19, 2019
Found minolta Dimage7i in back of parent's storage cabinet. batteries left in have leaked on the hinged door and would like to replace to see if camera will still work. great shape.
Put on proper protection for your skin/eyes, then remove the old ones, clean with some general cleaner or cola(yes like Coca Cola or Pepsi, etc. as it eats corrosion), then replace the batteries with new ones and see what happens!
3/24/2019 6:13:55 AM • Minolta Cameras • Answered on Mar 24, 2019
Al 1000 manuals
Most lens have a red spot on them. There is usually a red spot on camera (look on left side). The one on camera body is the unlock and needs to be pushed and held in as you rotate lens red spot towards the camera spot. When they line up you can remove lens. ?
10/21/2018 12:15:06 PM • Minolta Cameras • Answered on Oct 21, 2018
What year is sn#01001654 Minolta Maxxum HTsi plus?
Contact Konica-Minolta
1/24/2018 2:35:29 AM • Minolta Cameras • Answered on Jan 24, 2018
What card does my Minolta DiMAGE 1 use
The answer to this, and many other questions of a similar nature, may be contained in the manual. If you have no manual, you can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
3/2/2017 3:36:37 PM • Minolta Cameras • Answered on Mar 02, 2017
What is the biggest size memory card for my Dimage A1 Minolta Camera?
An older camera, the DiMage A1 came with a 16mb card. Some cameras are picky about which cards work best. Compact Flash cards are sold in different speeds and your camera may work faster with a faster card. This camera can use Compact Flash type I or type II, and is compatible with the microdrive card. Since this camera was introduced the capacities of Compact Flash cards have increased dramatically so I believe you should be able to use a larger card with no problems but I would check out some of the online photography sites to read about other's experiences. Here is one good resource: http://www.imaging-resource.com/ Hope this helps!
9/13/2016 3:37:21 PM • Minolta Cameras • Answered on Sep 13, 2016
You cannot find the age of Minolta lenses by the serial number, Minolta didn't use serial numbers like that. Some lenses have (c) xxxx for the year the type were first manufactured but that means the range, not that lens. This site has the different versions of the range. Minolta Konica Minolta Sony Alpha lens data
9/11/2014 3:18:31 PM • Minolta Cameras • Answered on Sep 11, 2014
Minolta 280PX TTL Flash Logo
2 questions posted
Top Minolta Cameras Experts
ADMIN Canada
ADMIN Canada
ray gallant
Tony Parsons
Tony Parsons
Are you a Minolta Camera Expert? Answer questions, earn points and help others
View Most Popular
Minolta Cameras
  • Minolta Cameras
Most Popular Question
old minolta camera quite few great
  • Cameras
