20 Most Recent Fahrenheat FUH5-4 Heater Questions & Answers
I have a Fahrenheat FUH5-4 heater in my garage. I
you may have 115v/120v instead of 208v/230v. check connection at wall switch or j-box.
1/2/2018 6:37:06 PM • Fahrenheat... • Answered on Jan 02, 2018
Fahrenheat 54b won't stay running long enough to heat
Fan maybe running to slow and allowing the elements to get too hot and open circuiting the cut out. This will be a fault with the fan or maybe dust and debris in the intake vents.
12/22/2013 1:51:33 PM • Fahrenheat... • Answered on Dec 22, 2013
0answers
Will not shut off
If you can't turn it off then it requires a new on/off switch to be fitted.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
3/1/2011 8:17:23 PM • Fahrenheat... • Answered on Mar 01, 2011
The heater does not stay on long enough to heat my
You could tripping the high temp limit this will be located near the heat exchanger When it shuts how long does the blower motor stay running? Do you have a meter?
12/15/2010 3:56:59 AM • Fahrenheat... • Answered on Dec 15, 2010
Does not shut off
check the thermostat to see that it is working proper, if it wont shut off, it is being told that it is not the temp. in the room that it is set for,
1/13/2010 2:49:21 PM • Fahrenheat... • Answered on Jan 13, 2010
Hi, I just purchased a FUH-54B at Northern Tool
It sounds like you have 120v from line 1 and line to to ground. What do you have between line 1 and line 2?
You should have 220 or 240v. If you dont have this
the problem is at the breaker. Are the wires going to the same breaker?
If you do have 220 or 240 between line 1 and line 2 at the unit, then it appears thr problem is at the unit,
probably the thermostat isn`t turned up high enough?
If it has a contactor, is it pulled in? If not then there is
a control problem. If you are skilled and confident you
could simply push the contactor in and it should
operate or have an electrician do it. Most of the time
you can bypass the thermostat and close the
contactor that way.
1/4/2010 2:13:56 AM • Fahrenheat... • Answered on Jan 04, 2010
I have a model UP2422B wall heater that glows very red when it first comes on and before the fan can kick in and cool it down. Is there a replacement heater available of the same size?
These heater elements should never glow red. The fan should come on at the same time the heater elements get power to heat up. If they turn red, the fan isn't starting fast enough, or is just turning too slow. Think of it like a toaster. They glow red but if you blow on them, they cool down until they aren't red anymore but they are still hot. I have this same heater. In the fan end opposite the fan motor, there is a little brass bushing (bearing) on the fan shaft that's mounted inside a rubber mount. Pop the rubber mount out of the heater housing, clean it up with degreaser and put grease or a heavy duty oil on the shaft and reassemble. If it still turns slow after that, it needs a new fan motor. You can probably match it up with the same motor from McMaster Carr or Grainger for cheaper than from Marley. I hope this helps
11/26/2023 2:02:20 PM • Fahrenheat... • Answered on Nov 26, 2023
My Fahrenheat Model FHP1500 will not heat. What can I do?
What is this? please give exact details.
4/12/2019 12:11:43 AM • Fahrenheat... • Answered on Apr 12, 2019
Fahrenheat mmhd1502ta loud buzzing
You may have to put a few drops of machine oil on the motor shaft. There is a felt washer on both ends of the motor shaft that absorbs and stores the lubricant. It probably is dry.
10/22/2016 9:02:56 PM • Fahrenheat... • Answered on Oct 22, 2016
I bought a Fahrenheat FZL4004 replacing an older model) and it wont stay on. It comes on, heats, blows, clicks off, & must be manually reset in order to come on again. Help?
Here is the link for the owner's manual. Or call customer service at 1-800-654-3545. http://www.manualshelf.com/manual/fahrenheat/fzl4004/instructions-assembly.html
3/1/2015 7:09:57 PM • Fahrenheat... • Answered on Mar 01, 2015
Fahrenheat FUH5-4 Heater Logo
Popular Tags
13 questions posted
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Paul Katynski
Paul Katynski
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Fahrenheat Heating & Cooling
Most Popular Question
will not shut off
  • Heating & Cooling
