20 Most Recent GE JVM1740DM Microwave Oven Questions & Answers
You'll need to carefully removed the keypad assembly and look for moisture etc.
GE JVM1740DM... • Answered on Nov 30, 2017
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
GE JVM1740DM... • Answered on Dec 29, 2010
Toss out the magnetron and replace with a new one, but make sure to discharge the capacitor before tinkering around inside or it will shock the hell out of you.
GE JVM1740DM... • Answered on Oct 11, 2010
Toss out the old magnetron and replace with a new one old chap. Also, make sure you discharge the capacitor before tinkering around inside or it will shock the hell out of you.
It's probably your bottom door switch. See this helpful file.
You can download GE owner's manuals and installation instructions here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
GE JVM1740DM... • Answered on May 04, 2010
That sounds like the interface controller which is just a little computer chip that cotrols everything and watches the signals from the touchpad is having problems. Usually these will behave like this and then just stop so your touchpad is totally dead. It may take out the time displays as well.
If you have warrenty from GE or the store it will be covered. If you are not covered then it can cost about the same or more as a new microwave as they will have to replace the board. Check your warrenty's, then check the repair cost and check replacement costs. Usually a new microwave is the cheapest.
GE JVM1740DM... • Answered on Apr 28, 2010
no, it is not controlled by a thermostat
GE JVM1740DM... • Answered on Nov 26, 2009
Request the manual directly from GE.
GE Microwave... • Answered on Mar 13, 2021
It's probably a stuck relay or you might want to check the door switches. Also try unplugging it for 30 seconds and replugging it.
GE Microwave... • Answered on Feb 23, 2021
GE JVM1740DM Microwave Oven Logo
Popular Tags
19 questions posted
Top GE Microwave Ovens Experts
gbob59
randymanfive
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
not heat food
  • Microwave Ovens
