20 Most Recent LG LD65EL Dehumidifier Questions & Answers
Unplug power cable,then take of front panel (2 screws).Then on left side on pipe se cliped sensor on pipe ,unclip then put in hot wather for 5 sec. Then put all back together and plug cable power and turn ON.That works on my Dehumidifier LG LD650EAL.
LG LD65EL... | Answered on Jun 08, 2017
When you install the drain tube, be sure that it is placed into the drain hole in the dehumidifier. You then will be able to "latch" the tube at the hose end by lowering onto the outer hole opening. This maintains a tight connection and the water will drain properly.
LG LD65EL... | Answered on Aug 19, 2013
I have a LG model LHD65EBL that first started icing up along the top edge during humid days. After several months of this, it finally stopped working and displayed CH01 with the bucket full indicator flashing.
I took apart the dehumidifier, removed the temperature sensor from the coil and rubbed it between my fingers. I then plugged in the unit and it started right up, confirming either a sensor or other circuit problem related to that sensor. For my model unit, I ordered sensor assembly #6877A30013L from RepairClinic.com for $21.75 + shipping.
When I received the assembly, I measured the new and old sensor with an ohm meter: new sensor = 5.5KOhms, old, defective sensor = 5.34KOhms. I installed the new sensor assembly and the unit is working fine.
Just because the bucket full indicator is flashing along with an error code does not mean there is a problem with the bucket full switch.
LG LD65EL... | Answered on Nov 14, 2011
Assuming you have already emptied the bucket (?), the bucket may not have been reinstalled properly. When this happens, you get what you described. Turn the unit OFF & unplug it. Remove the water collection bucket an reinstall it, so the it fits "squarely" into the bucket holder from top to bottom. It needs to make firm contact with the bucket removal safety switch on the left rear wall of the bucket holder. The bucket should not tilt down at the bottom when installed properly. Plug the cord back in and turn the unit ON. Set the humidity extraction level to 35%. If installed properly, the unit should turn ON within 5 seconds.
If the above does not solve the problem, the bucket safety removal switch may be broken. Remove the bucket and try activating it with your finger while the bucket is removed. If the unit doesn't start within a fem seconds, the switch is bad and should be replaced.
Hope this helped you troubleshoot and solve the problem. Thanks for choosing FixYa.
LG LD65EL... | Answered on Aug 15, 2011
Sounds like the compressor is inoperative. Most, if not all new units have no means of recharging the freon if it leaks out. If the coils are not cooling, the compressor is not operating and the unit will not dehumidify.
LG LD65EL... | Answered on Jun 26, 2011
Hi and welcome to FixYa, I am Kelly
Most likely the sensor assy has failed. See section 6 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5520042&diagram_id=28700153#d28700153
Detailed View: ($18.04)
http://www.appliancepartspros.com/part_details.aspx?part_id=4652359
This senses water and humidity levels.
Thanks for choosing FixYa,
Kelly
LG LD65EL... | Answered on May 28, 2011
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
LG LD65EL... | Answered on Sep 23, 2010
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
LG LD65EL... | Answered on Aug 29, 2010
the evrapitor coil rots out in about two years and all the freon leaks out. to repair it will cost more than you paid for it.
LG LD65EL... | Answered on Jul 31, 2010
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
LG LD65EL... | Answered on May 18, 2010
LG LD65EL Dehumidifier Logo
64 questions posted
Top LG Dehumidifiers Experts
jdthefixer
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
LG Dehumidifiers
  • LG Dehumidifiers
Most Popular Question
lg dehumidifier ld650eal code
  • Dehumidifiers
